Dear Expert, My CUBE Router this error. When I dial outside number. My ip phone 1st giving a dial tone then giving busy tone. Router#Jul 17 11:02:14.005: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: cr eated msg=0x257267C0 with ref...
Hi, I'm having a problem getting outbound calls working over a Verizon SIP trunk. Inbound work ok. The call flow is pretty straight forward Phone -> CUCM -> CUBE -> SIP trunk -> PSTN Outbound calls are getting a 403 error (ccsip messages and ccapi i...
Dears ; Please find the attached, in the attached you can find an estimation for an IP telephone solution " Cisco BE6000S" please note that we need your support do define what are the feature that this estimation can provide me with, such as ; IVR vo...
How can i view the list of users who performed any changes in CUCM?
Dear All, Wireless phone 7921 is getting unregistered automatically and comes up after reboot. I have checked status messages and found only two messages that are sepmacaddress.cnf.xml and Initialized. Help me with troubleshooting steps, please.
I have been asked for Forced translation should be +453272XXXX -> 0203433XXXX where the number +453272XXXX will be dials from UK IP Phone here we need tp configure so that ...when users from IP Phone dials (Full Number +453272XXXX) which is an In...
Hi guys, I would highly appreciate of you could clarify some nuances about Partitions and CSSs. Even though I watched and read about it I still can't understand the way it works. For example, I created 3 Route Patterns, 5 Partitions and 4 CSSs (pls s...
Hello,I was restarting some services in CUCM Serviceabilty - Control Center - Network ServicesI tried a Restart on the Cisco CallManager Admin service and it never came back up Need some help in getting this back up please!!!I tried using Putty and ...
Hello All, several questions about this. 1. How long of an outage can I expect? 2. We have a pub with 4 subs----do I change the DNS Settings on all five servers 3. Will I have to rehost my license files? 4. How do I access "Prime License Manage...
Hi all, I'm not sure if I can do this but having read a few threads on here it does appear to be possible so.... Say I set up a transformation set that attempts to take an incoming external call, converts it to say 7004455 where 4455 is the extensi...
Hi all I need to change IP addresses for my routers for MGCP and currently I have changed the confgiurations of one of my sites. The new configs show the updated new IP addresses but when I run show ccm-manager command I get the old IP address still...
Hello Actually I have 7821 SIP phone registered with Cisco2911 with IOS (C2900-UNIVERSALK9-M), Version 15.4(3)M2, (CUCM v10.5) and phone firmware "sip78xx.10-1-1SR1-4" on all 7821 phones, everything is ok but i can not see the call history and missed...
Hi, Whenever we receive call from PSTN and if we transfer it to internal extension. PSTN caller could not hear us. Please suggest if its a routing issue or mtp/codec issue. Config attached.
I have a setup with CIPC at a remote site which loses connectivity to the CUCM and, therefore, unregisters. CUCM traces show a keep alive timeout when the phone unregisters. The WAN interface from the site, outbound, has a lot of drops in the Criti...
Hello All, I am trying to upgrade 8851 SIP phone but getting md5 value error. I've tried to upgrade to cmterm-88xx-sip.10-3-1-20.k3.cop.sgn and cmterm-88xx-sip.11-0-1-11.k3.cop.sgn both gave me error about md5. I have checked md5 values and they mat...
Subject | Author | Posted |
07-23-2025 12:10 PM | ||
07-16-2025 12:00 PM | ||
07-15-2025 06:51 AM | ||
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM |
User | Count |
11 | |
2 | |
2 | |
1 | |
1 |
