CUCM 9.x and ELM in a Lab
CiscoRunner
I am looking to setup a CUCM cluster running version 9.x. As this is for a lab I only need a small amount of user licenses.
  • So, in version 9, I understand that ELM will be installed by default which is what I must use to upload and control licensing?
  • I do not need node licensing, just user licenses?
Is there anything else I need to consider? I make quite a few orders for licensing for our prodction cluster but will have spare licensing that I can deploy to my lab. Other than the user licenses, it seems I wont need anything else???
Thank you
Jaime Valencia
Correct, ELM is installed along every CUCM and CUC install yo do.
Yes, node licenses are no longer applicable in 9.x+, you only need user licenses
java
if this helps, please rate
Jaime Valencia
java
Perfect in that case I can install my lab and just upload 25 user licenses to have a fully functioning lab? Great
