CUCM 9.X with support for authentication and encryption of both signalling and payload data
ichehouri
Level 2
Level 2
we are in design phase for one customer and he is asking for the CUCM to support authentication and encryption of both signalling and payload data. Do we need to purchase tokens in this case or the system will provide that by default?
note that we will be using UCS servers and CUCM restricted version
regrads,
Ibrahim
Jaime Valencia
You need to buy two tokens to enable security in CUCM
java
if this helps, please rate
Jaime Valencia
java
if I am having CWMS part of my solution and a webEx meeting is there, will the meeting be encrypted? and what if i have the following scenarios:
1- All participants from external (PSTN and internet) and using Web and Audio
2- Participants are all Internal using Web, Audio and video
3- Participants are mixed (internal, PSTN and internet) and using Web and Audio
4- Participants are mixed (internal, PSTN and internet) and using Web, Audio and video
please advice if the encryption is supported in each scenario
regards,
Ibrahim Chehouri
