CUCM A Cisco DB not running / Database Communication Error !
Greeting All
I`m running CUCM 8.5 Pub and i wanted to change the IP address, i did it using the correct sequence number
Change the IP address under Administration page system->server
Then i changed it under the OS CLI set network ip eht0 IP_ADDRESS MASK
and i rebooted the server
However now i have database communication error when i try to login to The Administration Page and my Cisco DB service is not running ......
Any help please
Anonymous
Not applicable
Worked with Seifeddin on this issue.   He is running into the following software defect:
CSCtn29923 - CUCM 8.5 IP Address Change Procedure Fails resulting in outage
This issue is addressed by 8.5(1)Su2, or a workaround can be easily provided by TAC.
7 Replies 7
TunNyuntMoe
Well, I had similar problem a few days ago.
Here is how I fixed mine.
-Changed back to old IP and make sure all running.
To change new IP
-Under system->server, change that to NEW ip
-Under System->Cisco Unified CM, change approriate name. eg. CM_10.10.10.1
-Under OS administration setting->IP->Ethernet and change NEW ip/mask/gateway
syetem will auto reboot after that
*I did also changed the enterprise parameters url (I don't think that doesn't matter)
Hope this help.
Tun
Thanks Tun , i actually did the same and i even revert it back to the old ip address but still i have the same issue :( it looks like a bulg or something like that :(
For me I was a bit lucky. CM is not in production. So tried a few time (same steps though) and I thought works on fourth!
shalushar
Level 7
Level 7
Please refer the below link which has two solutions for this problem
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a0080b04158.shtml
Tx,
Hope this helps
Shalu
Anonymous
Not applicable
is it any way how could I fix it myself  without contacting TAC? Thanks.
Anonymous
Not applicable
You could go back to using the original IP address.
