CUCM Admin with IE no longer working
dino55088
hi,
running windows 10 with Edge in IE compatibility mode for UC servers
This was working fine until i applied latest MS patches on Tuesday June 14  and now i get the error "This page cannot be diplayed"
Page work fine though in Chrome.
ANybody else experiencing issues getting to https://x.x.x.x:8443/ccmadmin
6 Replies 6
Suresh Hudda
Do have this URL in trusted list of IE ?
Suresh
yes i do.
https://10.1.50.20
and actual url is  https://10.1.50.20:8443/ccmadmin
there are actually a few subs also- all exhibiting same behaviour with IE now (and all in Trusted sites).
thanks
D
It must be a local security issue..you may try to reach network administrator there.
Can you check it once bypassing proxy as well.
Suresh
found the issue:
Uninstall KB3163018  for Windows 10 fixes it.
many known issues with this breaking ssl/tls
Jaime Valencia
And what CUCM version???
java
if this helps, please rate
9.1
