I am trying to use the Analysis Manager to trace the call path between CUCM Subscriber and a MGCP GW.
I've added both the nodes and connectivity test is successful however after adding both of them to Call Record Repository, the connectivity test is failing in there.
I enabled HTTPS on the gateway and now analsysis manager is prompted for the certificate which I accepted. Now, when I run the connectvity test for the gateway under "Call Record Repository", I get the error "Service unavailable for this product".
"Debug ip http all" on the gateway generates following lines when I try to test connectivity from Inventory >> Call Record Repository.
Dec 4 14:35:08.486 MST: its_urlhook url: /ACSViewWebServices/ACSViewWebServices, method 2
Dec 4 14:35:08.486 MST: lds_urlhook, url=/ACSViewWebServices/ACSViewWebServices
Same status for CUCM. I have added the Subscriber in Inventory and connectivity test is successful however connectivity test in "Call Recording Repository" is failing with the error "Service unavailable for this product". I tried the Application administration credentials, OS administration credentails also fail giving different error.
The router is 2921 running "c2900-universalk9-mz.SPA.151-3.T1.bin"
CUCM version is: 8.5.1.10000-26
Let me know few pointers if someone was able to use this feature successfully.
thanks in advance,
Kapil Atrish
