10-19-2015 02:52 PM - edited 03-17-2019 04:37 AM
hi All,
I m actually using a CUCM connected to the CUBA 8.X with 4 client license.
I want add a second server to support 8 new client, so i have to use CUBA 9.X and to be installed to a new server ( CUBA 8. end of sale and support only max 6 client).
In wait to upgrade a license from CUBA 8.X to 9.X , i will in the first starting by using both server ( CUBA 8.X and CUBA 9.X).
I have the folowing questions :
1- it is possible to use two CUBA server coneected to one CUCM ?
2- It is possible to configure a call to be received in queue in both CUBA Client ?
Thanks in advance
Cham
Solved! Go to Solution.
10-19-2015 05:03 PM
I'm going to assume you refer to the CUBAC, right????
Because there is no product that just goes by CUBA
If so
1. Yes, configure completely separate integration
2. No
10-19-2015 05:03 PM
If so
2. No
10-19-2015 11:14 PM
Hi Jaime valencia,
Yes, I refer to the CUBAC .
Thanks a lot for the answer
