CUCM application password change
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-04-2016 06:05 AM - edited 03-17-2019 07:44 AM
Dear All,
I would like to change CUCM application password from CLI, but I am not sure which one to choose from the following commands.
CUCM version: 8.5.1.15900-4
utils reset_application_ui_administrator_name
utils reset_application_ui_administrator_password
utils reset_ui_administrator_name
utils reset_ui_administrator_password
Also do I need to update changed password on the dependent application servers like CUC, Mediasense & Informacast etc.,
Any other precautionary to be taken?
Thank you in advance
- Labels:
CUCM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2016 06:20 AM
Hi Syed,
For Application password reset followed the below link.
https://supportforums.cisco.com/document/65041/how-reset-passwords-cucm#Application_password
No Changes required on Unity
for Informant you will have to change the password at the below place.
JB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2016 06:23 AM
for media sense
i think AXL is on only user you use in integration, refer to the link below.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/mediasense/901/inst_admin/CUMS_BK_IFE33F4B_00_mediasense-install-and-admin-guide/CUMS_BK_IFE33F4B_00_mediasense-install-and-admin-guide_chapter_011.html#CUMS_TP_CDF98BB6_00
JB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2016 07:27 AM
Hi JB,
Thank you for your quick response.
I have gone through the above document, but it talks only about utils_reset_ui_administrator_password.
Do you mean to go ahead with the same?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2016 07:35 AM
Hi Syed,
i just did it on my LAB server for testing and it works like a champ.
JB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2016 07:47 AM
Thank you guys for your prompt support.
Will work on this and get back to you soon.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2016 07:41 AM
Hi Syed,
https://supportforums.cisco.com/document/65041/how-reset-passwords-cucm#Reset_Application_password_on_CUCM_8
On this link you will see the procedure very clear.
For the other systems, It depends of the user used for integration (AXL.. so on) so you can follow the comments of JB. So times, Unity have AXL integration so perhaps yo u have to update too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2016 07:11 AM
Whether you need to update any other app or not, will depend on what you used for the integration, if you're using the default admin account, or if you created a separate account for that integration.
java
if this helps, please rate
