CUCM Audit logs
John.McCartney1
In CUCM 8.6+ how long does the audit log remain before its overwritten? Can this be changed in Enterprise parameters?
I know you can grab them in RTMT but wasn't sure of the retention period.
Jaime Valencia
That really depends on how fast you fill them up so they have to cycle again and overwrite them.
No longer have an 8.6, but on 11.5 it says it keeps 250 files of 1 mb each.
java
if this helps, please rate
Thank you for your response!
I just looked on our 8.6 and 9.01 cluster and they both show 250 files each of 2mb size, Did they decrease the size in 11.5? Thanks again.
Seems that way, I don't recall changing any setting from the traces in my server.
java
