CUCM Backup A Cisco DB from SSH
Hello Friends,
I have CUCM 7.x and i need restarit. A Cisco DB is stopped and i don´t have backup. How can i backup DB from CLI command?....Wich is procedure?
I hope can you help me...
Jaime Valencia
You cannot just backup the DB from CLI, you need to use DRS to backup the system.
Use either the DRS GUI or the commands utils disaster_recovery, all commands and usage is here
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_3/cli_ref_713.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks javalenc...
Wich ii procedure for DRS GUI or the commands recovery?
I've already provided the link for CLI commands, review the usage and parameters there
GUI
Disaster Recovery System Administration Guide for  Release 7.1(2)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/7_1_2/drsag712.html
java
java
