CUCM BAT file
Ali Alqwasmi
Dears,
Good day...
I have an issue with Excel BAT file downloaded from CUCM. I want to export BAT file for adding new users. everytime I proess on the "Export to BAT Format" Button I get an error message from Excel "Run Time Error (13): Type Mismatch". When I click on Debug I find the following line in the VBA highlighted with yellow color:
If Trim(Range(getRange(intCount) & Trim(Str(i))).Value) <> "" Then
Can you please advise where is the mismatch? and how to correct it in order to export the BAT correctly.
Many thanks
Ali Alqwasmi
Manish Gogna
Hi Ali,
Can you set the Regional setting on the Windows PC ( Under Control Panel )  to 'English ( United States )' and test again.
Manish
Hi Manish
I found out what was the problem.
some of the names in the "Last Name" Field had spaces in them which caused the error to show. I removed the spaces and it worked fine.
Many thanks
Ali
