CUCM BAT, IPAD and VoiceMail
aalejo
Level 5
Level 5
Dear Sr
It is possible to bat a lot of ipad including the voicemail useir ID.
I can not find any fields on BAT for especific IPad/ Iphone/Android detail like Ldap directory, Voice mail, etc.
Since voice mail userID is especific for each user, can not be place on the phone template.
clileikis
Level 7
Level 7
Hi there,
Try using the Import/Export method by going to Bulk Administration > Import/Export > Phone and use the Import option to create/update the devices after you have modified those fields.
HTH,
Chris
