CUCM BAT problem
mmoulson1
Level 4
Level 4
Hi All,
I'm in the process of installing CUCM 8.5 for a customer I want to use BAT to 'Insert Phone with Users'.
I've done this before with CUCM5 & 7 and it worked without issue.
However in 8.5 I'm getting the following error on the job scheduler:
WARNING: Primary Extension does not exist on the devices/profiles controlled by the user. User will be inserted/updated without the primary extension
I have my "<Ext. No> in <Partition>" as my 'Primary Extension' field but no joy.
Any ideas? It's annoying because users cannot be imported into unity connection without a primary extension being set!
Thanks in advance.
Matty
2 Accepted Solutions
Rob Huffman
HI Matty,
Nice work my friend
Thanks for posting back with your workaround (+5) this will likely
help someone else down the road.
Cheers!
Rob
Hi Gary,
For the primary extension number you need to specify the partition, as above " in "
So your example:
pfinch,,,,,,,,119205,,,,,,,,,t,,,,,,Standard CCM End Users,SEP108CCFE1A141
Needs to be:
pfinch,,,,,,,,119205 in Internal,,,,,,,,,t,,,,,,Standard CCM End Users,SEP108CCFE1A141
Where 'Internal' is the name of the partition.
Let me know if that works.
Matty
8 Replies 8
Rob Huffman
Hey Matty,
It sounds like this bug
CSCtj31109
BAT Insert of Phones/Users does not associate Primary Extension
CallManager Versions:
8.0.1 and above
8.5.1.10000-26 (Customer Reported)
Issue/Symptoms:
When trying to add "Users and Phones" using the BAT tool the "Primary Extension" field on the user page does not get associated to a directory number.
Functionality does not work in any of the following cases:
BAT File Without Partition and Phone Line Template DN with Partition
BAT File Without Partition and Phone Line Template DN without Partition
BAT File With Partition and Phone Line Template DN with Partition
BAT File With Partition and Phone Line Template DN without Partition
Note: All of the above 4 cases do not work with Dummy MAC or Real MAC addresses
There are two type of errors we see in the BPS Logs:
1. If the BAT Phone Line Template DN has a Partition assigned to it then we see:
WARNING : PRIMARY EXTENSION :  does not exist. If all other values in the CSV are correct, then user will be inserted/updated without primary extension.
2. If the BAT Phone Line Template DN does not have a Partition assigned to it then we see
Work Around:
1) Insert Phone and User using "BAT->Phone-Users->Insert Phone-Users"
2) Update primary extension for users using "BAT->Users->Update Users"
Note: Workaround cannot be used if you have the Primary Extension assigned to a partition. In which case you will have to manually update each user.
Related Bug
Status
Fixed
Severity
3 - moderate
Last Modified
Jun 28,2011
Product
Cisco Unified Communications Manager (CallManager)
Platform
Dependent
Technology
nav
1st Found-in
8.0, 8.5(1)
Fixed-in
8.6(0.98000.51), 8.6(0.98000.18), 8.5(1.12013.1), 8.6(0.99981.2), 8.6(1.10000.1), 8.6(1.95040.1), 8.6(1.10001.1), 8.6(1.96000.51), 8.6(1.96000.1), 8.6(1.95190.40), 8.6(1.97011.1), 8.6(1.97011.2), 8.6(1.99989.1), 8.6(0.95180.9), 9.0(0.95010.1), 8.6(1.99986.1), 8.6(1.95020.58), 8.6(1.10000.43), 8.6(1.95020.1), 9.0(0.95070.38), 9.0(0.95070.39)
Cheers!
Rob
Hi Rob!
Wow a reply from the main man!
I agree I am probably hitting the bug however I’m managed to find a work around since I posted the above. If I add a ‘PRIMARY USER DEVICE’ field the ‘Primary Extension is then accepted!
I can’t think of any detriment that would be caused by the user having a device selected under ‘Mobility Information’
Kind Regards
Matt
Rob Huffman
HI Matty,
Nice work my friend
Cheers!
Rob
gary.hicks
I am running into this same issue when I try to update users.  I am running on version 8.6.2
I tried the work-around listed above and it did not help at all.  Anyone have any ideas?
Gary
Hi Gary,
Do you want to post your file so I can have a look?
Matty
gary.hicks
Matty,
These are just the test files before I do all 200 or so phones and users.  I have the phone insert and update users files.  Only updating users as I am using LDAP integration.  Everything But the assigning of the primary extension is working fine.
Phone file:
MAC ADDRESS,DESCRIPTION,DEVICE POOL,LOCATION,OWNER USER ID,DIRECTORY
NUMBER  1,LINE DESCRIPTION  1,ALERTING NAME  1,ASCII ALERTING NAME
1,DISPLAY  1,ASCII DISPLAY  1,LINE TEXT LABEL  1,ASCII LINE TEXT LABEL
1,EXTERNAL PHONE NUMBER MASK  1
108CCFE1A141,Paula Finch
x119205,Corporate_DP,Corporate_Location,pfinch,119205,Paula Finch
x119205,Paula Finch x119205,Paula Finch x119205,Paula Finch
x119205,3173969205
108CCF74162B,Jeff Schwarz
x119206,Corporate_DP,Corporate_Location,jschwarz,119206,Jeff Schwarz
x119206,Jeff Schwarz x119206,Jeff Schwarz x119206,Jeff Schwarz
x119206,3173969206
108CCF741A97,John Schwarz
x119207,Corporate_DP,Corporate_Location,joschwarz,119207,John Schwarz
x119207,John Schwarz x119207,John Schwarz x119207,John Schwarz
x119207,3173969207
108CCF741651,Jean Kelley
x119208,Corporate_DP,Corporate_Location,jkelley,119208,Jean Kelley
x119208,Jean Kelley x119208,Jean Kelley x119208,Jean Kelley
x119208,3173969208
8CB64F5618B9,Sandy Powell
x119209,Corporate_DP,Corporate_Location,spowell,119209,Sandy Powell
x119209,Sandy Powell x119209,Sandy Powell x119209,Sandy Powell
x119209,3173969209
8CB64F5613D4,Cheri Jones
x119210,Corporate_DP,Corporate_Location,cjones,119210,Cheri Jones
x119210,Cheri Jones x119210,Cheri Jones x119210,Cheri Jones
x119210,3173969210
108CCFE1798E,temp temp
x119211,Corporate_DP,Corporate_Location,,119211,temp temp x119211,temp
temp x119211,temp temp x119211,temp temp x119211,temp temp x119211,temp
temp x119211,temp temp x119211,3173969211
108CCFE18001,Helen Fortune
x112912,Corporate_DP,Corporate_Location,hfortune,112912,Helen Fortune
x112912,Helen Fortune x112912,Helen Fortune x112912,Helen Fortune
x112912,3173969212
8CB64F56164A,Laura Dujmovich
x119213,Corporate_DP,Corporate_Location,ldujmovich,119213,Laura
Dujmovich x119213,Laura Dujmovich x119213,Laura Dujmovich x119213,Laura
Dujmovich x119213,3173969213
108CCF741D1A,Kathy Thornton
x119214,Corporate_DP,Corporate_Location,kthornton,119214,Kathy Thornton
x119214,Kathy Thornton x119214,Kathy Thornton x119214,Kathy Thornton
x119214,3173969214
108CCFE1A16C,Linda Cochran
x119215,Corporate_DP,Corporate_Location,lcochran,119215,Linda Cochran
x119215,Linda Cochran x119215,Linda Cochran x119215,Linda Cochran
x119215,3173969215
8CB64F5616F7,Betty Uebelhor
x119216,Corporate_DP,Corporate_Location,buebelhor,119216,Betty Uebelhor
x119216,Betty Uebelhor x119216,Betty Uebelhor x119216,Betty Uebelhor
x119216,3173969216
8CB64F56148C,David Hunt
x119217,Corporate_DP,Corporate_Location,dhunt,119217,David Hunt
x119217,David Hunt x119217,David Hunt x119217,David Hunt x119217,David
Hunt x119217,David Hunt x119217,David Hunt x119217,3173969217
108CCF7417B1,Debbie Hubbard
x119218,Corporate_DP,Corporate_Location,dhubbard,119218,Debbie Hubbard
x119218,Debbie Hubbard x119218,Debbie Hubbard x119218,Debbie Hubbard
x119218,3173969218
108CCF741643,Bonnie Ade
x119219,Corporate_DP,Corporate_Location,bade,119219,Bonnie Ade
x119219,Bonnie Ade x119219,Bonnie Ade x119219,Bonnie Ade x119219,Bonnie
Ade x119219,Bonnie Ade x119219,Bonnie Ade x119219,3173969219
8CB64F5613D3,Mike Citrino
x119223,Corporate_DP,Corporate_Location,mcitrino,119223,Mike Citrino
x119223,Mike Citrino x119223,Mike Citrino x119223,Mike Citrino
x119223,3173969223
081735D4245E,Brenda Snell
x119225,Corporate_DP,Corporate_Location,bsnell,119225,Brenda Snell
x119225,Brenda Snell x119225,Brenda Snell x119225,Brenda Snell
x119225,3173969225
8CB64F5618CF,Aaron Williamson
x119227,Corporate_DP,Corporate_Location,awilliamson,119227,Aaron
Williamson x119227,Aaron Williamson x119227,Aaron Williamson
x119227,Aaron Williamson x119227,Aaron Williamson x119227,Aaron
Williamson x119227,Aaron Williamson x119227,3173969227
108CCF7419BF,x119228,Corporate_DP,Corporate_Location,,119228,x119228,x1
19228,x119228,x119228,x119228,x119228,x119228,3173969228
8CB64F56169D,Chris Patterson
x119229,Corporate_DP,Corporate_Location,cpatterson,119229,Chris
Patterson x119229,Chris Patterson x119229,Chris Patterson x119229,Chris
Patterson x119229,3173969229
108CCFE1A207,Conference Conference
x119230,Corporate_DP,Corporate_Location,,119230,Conference
x119230,Conference x119230,Conference x119230,Conference
x119230,3173969230
108CCFE17E6D,SmallConf SmallConf
x119231,Corporate_DP,Corporate_Location,,119231,SmallConf
x119231,SmallConf x119231,SmallConf x119231,SmallConf x119231,SmallConf
x119231,SmallConf x119231,SmallConf x119231,3173969231
Update Users:
USER ID,MANAGER USER ID,DEPARTMENT,DEFAULT PROFILE,USER LOCALE,PASSWORD,PIN,TELEPHONE NUMBER,PRIMARY EXTENSION,ASSOCIATED PC,IPCC EXTENSION,MAIL ID,PRESENCE GROUP,SUBSCRIBE CALLING SEARCH SPACE,DIGEST CREDENTIALS,REMOTE DESTINATION LIMIT,MAXIMUM WAIT TIME FOR DESK PICKUP,ALLOW CONTROL OF DEVICE FROM CTI,ENABLE MOBILITY,ENABLE MOBILE VOICE ACCESS,PRIMARY USER DEVICE,ENABLE EMCC,NAME DIALING,USER GROUP 1,CONTROLLED DEVICE 1
jschwarz,,,,,,,,119206,,,,,,,,,t,,,,,,Standard CCM End Users,SEP108CCF74162B
joschwarz,,,,,,,,119207,,,,,,,,,t,,,,,,Standard CCM End Users,SEP108CCF741A97
jkelley,,,,,,,,119208,,,,,,,,,t,,,,,,Standard CCM End Users,SEP108CCF741651
spowell,,,,,,,,119209,,,,,,,,,t,,,,,,Standard CCM End Users,SEP8CB64F5618B9
cjones,,,,,,,,119210,,,,,,,,,t,,,,,,Standard CCM End Users,SEP8CB64F5613D4
hfortune,,,,,,,,112912,,,,,,,,,t,,,,,,Standard CCM End Users,SEP108CCFE18001
ldujmovich,,,,,,,,119213,,,,,,,,,t,,,,,,Standard CCM End Users,SEP8CB64F56164A
kthornton,,,,,,,,119214,,,,,,,,,t,,,,,,Standard CCM End Users,SEP108CCF741D1A
lcochran,,,,,,,,119215,,,,,,,,,t,,,,,,Standard CCM End Users,SEP108CCFE1A16C
buebelhor,,,,,,,,119216,,,,,,,,,t,,,,,,Standard CCM End Users,SEP8CB64F5616F7
dhunt,,,,,,,,119217,,,,,,,,,t,,,,,,Standard CCM End Users,SEP8CB64F56148C
dhubbard,,,,,,,,119218,,,,,,,,,t,,,,,,Standard CCM End Users,SEP108CCF7417B1
bade,,,,,,,,119219,,,,,,,,,t,,,,,,Standard CCM End Users,SEP108CCF741643
mcitrino,,,,,,,,119223,,,,,,,,,t,,,,,,Standard CCM End Users,SEP8CB64F5613D3
bsnell,,,,,,,,119225,,,,,,,,,t,,,,,,Standard CCM End Users,SEP081735D4245E
awilliamson,,,,,,,,119227,,,,,,,,,t,,,,,,Standard CCM End Users,SEP8CB64F5618CF
cpatterson,,,,,,,,119229,,,,,,,,,t,,,,,,Standard CCM End
Gary
Hi Gary,
So your example:
Needs to be:
Matty
gary.hicks
Thanks Matty,
That was the issue.
