11-28-2022 04:47 AM
Hello ,
These tow certs CAP-RTP-001 and CAP-RTP-002 are installed the cucm as callmanager-trust and capf-trust , they will be expired in 2023 . How can we get new / valid certs .
Thanks.
Solved! Go to Solution.
01-10-2023 01:40 PM
01-10-2023 09:57 PM
There are likely more certificates present with that description if you change the filter criteria. Quite likely both of these are replaced with other certificates as one is expiring in a few days and the other in a few months.
01-11-2023 07:34 PM
We have the same issue reported here and have a TAC case open, sadly TAC seems to not know anything about this issue. If we needed to upgrade from 12.5.1 version we are running I would think TAC would be telling us that. Not saying the upgrade path is incorrect, I am just saying we would like official word from Cisco as to what steps to take. planning a version upgrade in less than 30 days is a big ask for our company. -1 for Cisco TAC on these certs.... I guess I will requeue my tac case.
01-12-2023 07:10 AM
TAC seems to not know what you guys are talking about as far as the RTP certs being replaced or updated by a CUCM upgrade. below is what they told me, sadly I don't trust this process TAC is recommending.
01-12-2023 07:44 AM - edited 01-12-2023 07:50 AM
These are all the certificates that we have present in the system that is used for validating the MIC. We have not added any of these manually, they all came during various upgrades of the CM. The list is from a 12.5SU5 installation.
CallManager-trust | Cisco_Root_CA_2048_5ff87b282b54dc8d42a315b568c9adff | Self-signed | RSA | Cisco_Root_CA_2048 | Cisco_Root_CA_2048 | 05/14/2029 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CallManager-trust | Cisco_Manufacturing_CA_III_04302a0b364ce2da93 | CA-signed | RSA | Cisco_Manufacturing_CA_III | Cisco_Basic_Assurance_Root_CA_2099 | 05/26/2099 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CallManager-trust | ACT2_SUDI_CA_61096e7d00000000000c | CA-signed | RSA | ACT2_SUDI_CA | Cisco_Root_CA_2048 | 05/14/2029 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CallManager-trust | Cisco_Root_CA_M2_01 | Self-signed | RSA | Cisco_Root_CA_M2 | Cisco_Root_CA_M2 | 11/12/2037 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CallManager-trust | Cisco_Manufacturing_CA_6a6967b3000000000003 | CA-signed | RSA | Cisco_Manufacturing_CA | Cisco_Root_CA_2048 | 05/14/2029 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CallManager-trust | Cisco_Basic_Assurance_Root_CA_2099_01a65af15ee994ebe1 | Self-signed | RSA | Cisco_Basic_Assurance_Root_CA_2099 | Cisco_Basic_Assurance_Root_CA_2099 | 05/26/2099 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CallManager-trust | High_Assurance_SUDI_CA_0a6475524cd8617c62 | CA-signed | RSA | High_Assurance_SUDI_CA | Cisco_Root_CA_2099 | 08/09/2099 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CallManager-trust | Cisco_Manufacturing_CA_SHA2_02 | CA-signed | RSA | Cisco_Manufacturing_CA_SHA2 | Cisco_Root_CA_M2 | 11/12/2037 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CallManager-trust | Cisco_Root_CA_2099_019a335878ce16c1c1 | Self-signed | RSA | Cisco_Root_CA_2099 | Cisco_Root_CA_2099 | 08/09/2099 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CAPF-trust | Cisco_Root_CA_2048_5ff87b282b54dc8d42a315b568c9adff | Self-signed | RSA | Cisco_Root_CA_2048 | Cisco_Root_CA_2048 | 05/14/2029 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CAPF-trust | Cisco_Manufacturing_CA_III_04302a0b364ce2da93 | CA-signed | RSA | Cisco_Manufacturing_CA_III | Cisco_Basic_Assurance_Root_CA_2099 | 05/26/2099 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CAPF-trust | ACT2_SUDI_CA_61096e7d00000000000c | CA-signed | RSA | ACT2_SUDI_CA | Cisco_Root_CA_2048 | 05/14/2029 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CAPF-trust | Cisco_Root_CA_M2_01 | Self-signed | RSA | Cisco_Root_CA_M2 | Cisco_Root_CA_M2 | 11/12/2037 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CAPF-trust | Cisco_Manufacturing_CA_6a6967b3000000000003 | CA-signed | RSA | Cisco_Manufacturing_CA | Cisco_Root_CA_2048 | 05/14/2029 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CAPF-trust | Cisco_Basic_Assurance_Root_CA_2099_01a65af15ee994ebe1 | Self-signed | RSA | Cisco_Basic_Assurance_Root_CA_2099 | Cisco_Basic_Assurance_Root_CA_2099 | 05/26/2099 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CAPF-trust | High_Assurance_SUDI_CA_0a6475524cd8617c62 | CA-signed | RSA | High_Assurance_SUDI_CA | Cisco_Root_CA_2099 | 08/09/2099 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CAPF-trust | Cisco_Manufacturing_CA_SHA2_02 | CA-signed | RSA | Cisco_Manufacturing_CA_SHA2 | Cisco_Root_CA_M2 | 11/12/2037 | This certificate was used to sign the MIC installed on Cisco endpoint. Presence of this certificate allows the end point to communicate securely with UCM using the MIC when associated with a secure profile. |
CAPF-trust | Cisco_Root_CA_2099_019a335878ce16c1c1 | Self-signed | RSA |
01-12-2023 07:48 AM
Hi Roger , which version is this ? i could not see CAP certs. are they already deleted ?
01-12-2023 07:49 AM
what version are you running that supplied a resolution to this issue?
01-12-2023 10:05 AM
I updated my response with this.
01-12-2023 07:39 AM
You are right, TAC just gave me the same answer
01-12-2023 07:50 AM
This seems like Cisco did not prepare for their own certs to expire or the TAC agents do not know how to address this issue. we should not be forced to install LSC on phones just to have them register, if I am understanding the outcome correctly. I have requested a webex session to review this issue as I do not think we are addressing the issue here. people in this forum say the certs are replace via a version upgrade yet I have 3 clusters on different versions and they all have the same expire dates! I would love to know what version of CUCM would resolve this issue, and why would TAC not know about this version upgrade to resolve the issue?
01-13-2023 11:43 PM
I don’t know for others, but I’m actually not saying that these specific are updated by a version upgrade. What I try to get across is that MIC validation certificates are updated by a version upgrade, that does not mean that these specific certificates are the once being updated. By looking at what is current for MIC validation certificates my understanding is that version upgrades puts in other certificates that are to be used for this.
01-13-2023 04:10 PM
In case it helps anyone else who finds this thread, I had similar questions about the CAP-RTP-001 and CAP-RTP-002 certificates that expire in 2023.
Our CUCM cluster is version 14.0.1.11900-132. We have the CAPF service activated but the cluster is not in Mixed Mode. I deleted the expiring CAP-RTP-001 cert from our CallManager-trust and CAPF-trust and it did not cause any problems. The phones continued to be able to register to CUCM after the certificate was deleted.
I plan to delete the CAP-RTP-002 certificate before it expires as well.
01-13-2023 05:49 PM
Do you have valid LSC certificates on your phones?
01-16-2023 01:46 PM
No, we do not have an LSC installed on our phones.
01-17-2023 06:16 AM
Did you restart the callmanager and capf trust service on the servers in the cluster after deleting these?
