02-21-2014 02:57 PM - edited 03-16-2019 09:51 PM
Hi there,
by any chance you know of any way to bypass this limitation from CUCM? - I have been looking everywhere with no luck. when we download the CDR reports from CUCM it comes with all the translated numbers instead of the Original Called Number.
Please help!!!
Solved! Go to Solution.
02-22-2014 04:33 AM
Hi Andres
Based on the below document
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/8_5_1/cdrdef/cdradmin/cdrfdes.html
Please rate all useful information
02-22-2014 04:33 AM
Hi Andres
03-10-2016 08:10 AM
This is a very old question, but time and experience have shown me that there are many wasy to skin a cat.
This can be accomplished in many ways and even without applying translation patterns in CUCM and then define all DIDs into the CUBE gateway which was my case. This client has 500+ DIDs but this can be accomplished in new IOS releases where a new Dial-Peer that looks at a list of DIDs in flash can be used, very little maintenance and overhead.
Create a file with e164 numbers and call it e164-pattern-map.cfg
the file will contain the following:
3051111111
3051111112
9541111212
8912221212
Save the file in Flash, and the following is how you call it:
voice class e164-pattern-map 100
url flash:e164-pattern-map.cfg
dial-peer voice 100 voip
destination e164-pattern-map 100
session target ipv4:x.x.x.x
