ā12-13-2012 01:04 AM - edited ā03-16-2019 02:42 PM
I have several voice gateways (2821, 2851, 3825) running IOS with SPSERVICESK9 feature set, version 12.4(24)T1 (or higher), connected to CUCM version 7.1.5.31900-3.
The gateways are configured as H.323 gateways on the CallManager,
and are configured as PSTN gateways with PRI interface and SIP gateways to MS MOC.
In forwarded calls to PSTN I need to send "Last Redirect Number (External)" calling party number,
in forwarded calls to MS MOC I would need to send "Originator" calling party number (as it is an internal call).
Is there any way how to configure CUCM and the gateways to to use different "Calling Party Selection" for calls going to different destinations?
Regads Frantisek Opravil
ā12-18-2012 01:49 PM
For the forwarded calls to MOC, you can modify the diversion header on the forwarded calls like described here:
https://supportforums.cisco.com/docs/DOC-19051
For the forwarded to PSTN calls, rather than rehash a much covered topic, I'll just post some links:
https://supportforums.cisco.com/thread/2069444
https://supportforums.cisco.com/message/1111886#1111886
https://supportforums.cisco.com/message/1076950#1076950
ā01-22-2013 01:11 AM
thank you for your reply.
I have red references from your reply and I conclude, that
If there are forwarded external calls in the CUCM cluster, and
some are forwarded to PSTN network (and PSTN provider does not provide "no screening CLI") and
some are forwarded to MOC (Microsoft Office Communicator, withing our company, i.e. they are internal calls)
then I need 2 different "calling party selection" in the CUCM Gateway configuration
"last redirect number (external)" for forwarded calls outgoing to PSTN, and
"originator" for forwarded calls outgoing to MOC
and it cannot be configured concurrently for a single gateway;
I need 2 gateways (to PSTN and to MOC) or a gateway to PSTN and SIP trunk to MOC.
Regards Frantisek Opravil
