CUCM / CUBE Call rings but calling-side keeps ringing on pick-up
t.vandenheuvel
Hello all,
I have a CUCM install connected to a 2801 set up as an H232 gateway connected to 3 voip trunks.  Everything has been working fine untill a while ago.
When I get an inbound call and I pick up, the phone acts as it should but the calling side keeps getting the ringtone as if no one picks up.  When I hang up the calling side also gets disconnected.  I have this problem only on inbound calls on one trunk.  Outbound calls and everything on the other trunks works fine.
I contacted the provider of the trunk but they say nothing has changed but they see a SIP 500 internal server error coming from my end.  I did quite some troubleshooting but I can't seem to find the problem.  Most of the config is similar on all three trunks and it has been working flawlessly for quite a while.
I suspect it could have something to do with the video capabilities or codecs (dynamic vs static payload) on the non-working trunk but I don't understand why it has worked before and now doesn't anymore.
Hope someone can help me out here.
I have attached SIP debugs for a call on a working trunk and one on the non-working one.
Config:
vr1-lnkn#sh run
Building configuration...
Current configuration : 6603 bytes
! Last configuration change at 14:44:27 UTC Mon Oct 15 2012 by Admin
version 15.1
service password-encryption
hostname vr1-lnkn
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa authorization network default local
aaa session-id common
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.4.1 192.168.4.50
ip dhcp excluded-address 192.168.4.101 192.168.4.255
ip dhcp pool VOICE
   network 192.168.4.0 255.255.255.128
   dns-server 192.168.5.11 192.168.5.12
   default-router 192.168.4.1
   option 150 ip 192.168.4.11
ip dhcp pool KTPH01
   host 192.168.4.21 255.255.255.128
   client-identifier 0100.1121.111a.d8
ip cef
ip domain name <deleted>
ip name-server 192.168.5.11
no ipv6 cef
voice service voip
ip address trusted list
  ipv4 192.168.4.0 255.255.255.128
  ipv4 <deleted> 255.255.255.224
  ipv4 <deleted> 255.255.255.255
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
  emptycapability
  h225 id-passthru
  h245 passthru tcsnonstd-passthru
sip
  bind control source-interface Loopback1
  bind media source-interface Loopback1
  session transport tcp
  no call service stop
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g729r8
voice translation-rule 8787
rule 1 /<deleted>/ /1660/
rule 2 /<deleted>/ /1665/
voice translation-rule 3185401
rule 1 /^<deleted>/ //
voice translation-rule 99051000
rule 1 /<deleted>/ /1665/
rule 2 /<deleted>/ /1668/
rule 3 /<deleted>/ /1660/
voice translation-profile 3185401
translate called 3185401
voice translation-profile 8787
translate called 8787
voice translation-profile 99051000
translate called 99051000
voice-card 0
license udi pid CISCO2801 sn FCZ105020RC
username admin privilege 15 secret 5 <deleted>
ip ssh version 2
interface Loopback0
description ROUTER ID
ip address 192.168.5.217 255.255.255.252
interface Loopback1
description VOIP GATEWAY
ip address 192.168.4.1 255.255.255.255
h323-gateway voip bind srcaddr 192.168.4.1
interface Loopback99
description MGMT
ip address 192.168.6.245 255.255.255.255
interface FastEthernet0/0
description TO CS1-2-23
ip address 192.168.5.221 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
description TO CS1-3-23
ip address 192.168.5.225 255.255.255.252
duplex auto
speed auto!
router ospf 1
router-id 192.168.5.217
network 192.168.4.1 0.0.0.0 area 0
network 192.168.5.216 0.0.0.3 area 0
network 192.168.5.220 0.0.0.3 area 0
network 192.168.5.224 0.0.0.3 area 0
network 192.168.6.245 0.0.0.0 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.5.205
logging esm config
snmp-server community <deleted> RO
snmp-server location <deleted>
snmp-server contact <deleted>
control-plane
voice-port 0/0/0
voice-port 0/0/1
ccm-manager mgcp
mgcp
mgcp call-agent 192.168.4.11 service-type mgcp version 0.1
mgcp bind control source-interface Loopback1
mgcp bind media source-interface Loopback1
mgcp profile default
dial-peer voice 2901 pots
description FXS PORT 1
service mgcpapp
port 0/0/0
dial-peer voice 2902 pots
description FXS PORT 2
service mgcpapp
port 0/0/1
dial-peer voice 2000 voip
description ANALOG LINES
destination-pattern 2...
session target ipv4:192.168.4.11
dtmf-relay h245-alphanumeric
codec transparent
ip qos dscp cs5 media
ip qos dscp cs5 signaling
dial-peer voice 1 voip
description <PROVIDER Y> OUTGOING
destination-pattern .T
session protocol sipv2
session target dns:<deleted>
session transport udp
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1660 voip
description <PROVIDER Y> INCOMING
translation-profile outgoing 3185401
destination-pattern <deleted>.
incoming called-number <deleted>.
voice-class codec 1
no vad
dial-peer voice 1604 voip
description <PROVIDER X> INCOMING
translation-profile outgoing 8787
destination-pattern 08787.....
incoming called-number 08787.....
voice-class codec 1
no vad
dial-peer voice 1901 voip
description SKYPE INCOMING <deleted>
translation-profile outgoing <deleted>
destination-pattern <deleted>......
incoming called-number <deleted>......
codec transparent
sip-ua
credentials username <deleted> password 7 <deleted> realm <PROVIDER Y>
credentials username <deleted> password 7 <deleted> realm <PROVIDER X>
credentials username <deleted> password 7 <deleted> realm sip.skype.com
authentication username <deleted> password 7 <deleted> realm <PROVIDER Y>
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers register 250
registrar 1 dns:<PROVIDER Y> expires 3600
registrar 2 dns:<PROVIDER X> expires 3600
registrar 3 dns:sip.skype.com expires 3600
banner motd ^C
! UNAUTHORIZED ACCESS PROHIBITED !
^C
line con 0
exec-timeout 30 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 30 0
privilege level 15
logging synchronous
transport input ssh
line vty 0 4
access-class SSH in
exec-timeout 0 0
privilege level 15
logging synchronous
transport input ssh
scheduler allocate 20000 1000
ntp server <deleted>
end
vr1-lnkn#
Thanks!
Hi Tom,
          Did you ever find a resolution for your issue? I seem to be having an identical issue including getting the 500 internal server errors etc.
          Any help or info you may have would be much appreciated.
     regards,
                    Zachariah
I did.
After asking a few times it seemed my provider indeed had some changes done in their system: H263 and H264 video codecs were added.
After they disabled them again for my trunk everything worked again as usual.
