Recovery Disk
Leonardo Santana
Hello
I need to run the Recovery disk on CUCM  8.0.3.22900-5 and i have  the recovery disk 8.0.3.20000-2  there is no problem correct ?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Harmit Singh
Hi leonardo,
You can use that version. As long as both your CUCM and recovery disk major and minor versions are the same there is no problem. In this case it is 8.0.3.
HTH.
Harmit.
Sent from Cisco Technical Support Android App
Harmit Singh
Hi leonardo,
HTH.
Harmit.
Thanks Harmit
I run the recovery disk and the CUCM is fine now!
Leonardo Santana
Leonardo Santana
