05-18-2022 03:40 AM
Hello All,
I have an issue with my cucm nodes. They seems to be an issue with the DB replication.
When I run utils dbreplication runtimestate on the publisher, I find that some of the nodes are not replicating. Kindly find output below:
login as: O******
OSadmin@10.*.*.6's password:
Command Line Interface is starting up, please wait ...
Welcome to the Platform Command Line Interface
VMware Installation:
2 vCPU: Intel(R) Xeon(R) Gold 6130 CPU @ 2.10GHz
Disk 1: 160GB, Partitions aligned
8192 Mbytes RAM
admin:
admin:
admin:
admin:utils db rep
admin:utils dbreplication run
admin:utils dbreplication runtimestate
Server Time: Wed May 18 11:17:50 WAT 2022
Cluster Replication State: BROADCAST SYNC ended at: 2022-05-16-23-05
Sync Result: SYNC COMPLETED on 706 tables out of 706
Sync Status: All Tables are in sync
Use CLI to see detail: 'file view activelog cm/trace/dbl/20220516_200620_dbl_repl_output_Broadcast.log'
DB Version: ccm11_5_1_15900_18
Repltimeout set to: 300s
PROCESS option set to: 1
Cluster Detailed View from mmosnighcpub (8 Servers):
PING DB/RPC/ REPL. Replication REPLICATION SETUP
SERVER-NAME IP ADDRESS (msec) DbMon? QUEUE Group ID (RTMT) & Details
mmosnighcpub 10.*.*.6 0.014 Y/Y/Y 0 (g_2) (2) Setup Completed
mmosnighcsub 10.*.*.7 0.292 Y/Y/Y -- (-) (3) Out Of Sync
mmosnigkucsub 10.*.*.7 104.624 -/N/- -- (-) (-) Not Requested
mmosnigkacsub 10.*.*.7 47.112 Y/Y/Y 0 (g_6) (2) Setup Completed
mmosnigibcsub 10.*.*.7 13.845 Y/Y/Y -- (-) (3) Out Of Sync
mmosnigotcsub 10.*.*.7 86.943 Y/Y/Y 0 (g_9) (2) Setup Completed
mmosnigabcsub 10.*.*.7 24.216 Y/Y/Y 0 (g_7) (2) Setup Completed
mmosnigamcsub 10.*.*.7 28.998 Y/Y/Y 0 (g_8) (2) Setup Completed
I have also attached screenshots from the CUCM Unified reporting page.
Thanks in anticipation
05-23-2022 02:17 AM
Hello @Manish Gogna , @Jitender Bhandari kindly assist
05-23-2022 07:28 AM
Recommend you to follow the steps outlined in this document.
