07-06-2016 02:49 PM - edited 03-18-2019 12:01 PM
DearAll,
Can somebody help me how to create , National , Local and international dial pattern in CUCM for saudiarabia
National 05xxxxxxxx and 01xxxxxxxx
Local 8xxxxxx
International 00
07-06-2016 03:09 PM
Hi. Samsam
You just need to make sure you are sending the correct number of. Digits to service provider with the prefix they want.
So if it mgcp then maniplution will be done at cucm only otherwise for H323 and SIP you can either do it on GW as well.
Eg if user dials 900 for intl calls and provide accepts with 00 only then forward all digits to GW and then strip 9 before sending it out to provider.
07-06-2016 03:54 PM
Why don't you use the dial plan for CUCM??
There's a version for SA.
07-10-2016 02:51 AM
Dear Jaime,
Am stuck in route filter.
