BLF-SPEED-DIAL STILL NOT WORKING
isaaco001
Level 3
Level 3
Dear Community,
I have configured the blf-speed-dial on some phones running on sip i.e 7945 and was working just fine.After sometime the lights stops blinking.Despite by efforts to troubleshoot this by removing the latest configs that i did which i thought stopped the lights working,still there was the same issue.The last configs that i did was on class of restriction.I have attached the configs for blf where extension 121 is monitoring 120(bfl.txt running config) and also 103 monitoring 122 (debugs output) :
debug presence all
debug voice ccapi inout
debug ccsip all
debug voip application all
and my running config(blf)
show presence subscription
Presence Active Subscription Records:
show subscription sip
ASNL Active Subscription Records Summary:
Number of active subscriptions: 0
Client EXPIRES(sec) EVENT
121 0 presence
121 0 presence
150 0 presence
103 0 presence
Some new sessions have started during the show command.
The current number of active subscriptions = 4
show subscription asnl session active
ASNL Active Subscription Records Details:
No active subscriptions found.
show subscription local
Please advice how i can best troubleshoot this problem.Any suggestions are welcomed.
Thank you.
aaavvvmmm
BLF on a router takes a lot of resources. I think you router is exhausted. I had a similar problem. What type of router you have? I  believe you over the MAX BLF the router can handle.
BR,
Aviram
Its a 2951 voice router.However i am not sure how many max blf it can handle,i will check with configs again.I think i may have to remove redundant configs especially on the dial-peers and hope it works.I will keep you updated.Thanks,you've given me a good idea for troubleshooting the problem.
Isaac.
