CUCM Disconnect Code 41 After 2 Rings before 3 ring call completes
damessmer
Started getting disconnect code 41 after 2 rings on only 1 extension.  If you answer the call before the 2nd ring the call completes as normal. All other extensions work fine.
See call details
successful call
Message Details
SENDER: 172.27.199.20
GUID: 8b72ca80-56614172-53f0b-14c71bac@172.27.199.20
MSG_LABEL: INVITE
RECEIVER: [SEP5486BC7E14DC] 172.27.199.132
MAC_ADDRESS: SEP5486BC7E14DC
MSGTAG: 22756959
MSG_TYPE: UCM_CTRACE
CORRELATIONID: 1,100,10,1.926744^172.27.199.1^*
TIMESTAMP: 2023/11/28 13:37:22.260
Detailed Sip Message
There is no SIP message to display!
Please verify the following:
1.Check if the "Enable SIP Call Processing Trace" check box in "Unified Serviceability Webpage --> Trace --> Configuration --> CM Services --> Cisco CallManager" is enabled
2.Check if the trace level is set to State Transition, Significant, Arbitrary or Detailed
Message In Log File
2023/11/28 13:37:22.251|SIPT|0|UDP|IN|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|63995|1,100,10,1.926744^172.27.199.1^*|22756957|62668A63-8D5C11EE-A00C9738-1F24A1A8@172.27.199.1|INVITE
2023/11/28 13:37:22.252|SIPT|0|UDP|OUT|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|5060|1,100,10,1.926744^172.27.199.1^*|22756958|62668A63-8D5C11EE-A00C9738-1F24A1A8@172.27.199.1|100 Trying
2023/11/28 13:37:22.255|CC|SETUP|28392015|28392016|2513634312|5827|5827
2023/11/28 13:37:22.259|CC|OFFERED|28392015|28392016|2513634312|5827|5827|PCP_SIP_Thomasville_GWY|SEP5486BC7E14DC
2023/11/28 13:37:22.260|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,10,1.926744^172.27.199.1^*|22756959|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|INVITE
2023/11/28 13:37:22.262|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,10,1.926744^172.27.199.1^*|22756960|8b72ca80-56614172-53f0c-14c71bac@172.27.199.20|INVITE
2023/11/28 13:37:22.262|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,10,1.926744^172.27.199.1^*|22756961|8b72ca80-56614172-53f0d-14c71bac@172.27.199.20|INVITE
2023/11/28 13:37:22.263|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,10,1.926744^172.27.199.1^*|22756962|8b72ca80-56614172-53f0e-14c71bac@172.27.199.20|INVITE
2023/11/28 13:37:22.264|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.340^172.27.199.132^*|22756963|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|100 Trying
2023/11/28 13:37:22.265|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,14,263202.349^172.27.199.147^*|22756964|8b72ca80-56614172-53f0c-14c71bac@172.27.199.20|100 Trying
2023/11/28 13:37:22.267|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,14,263227.299^172.27.199.122^*|22756965|8b72ca80-56614172-53f0e-14c71bac@172.27.199.20|100 Trying
2023/11/28 13:37:22.272|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,14,263222.231^172.27.199.123^*|22756966|8b72ca80-56614172-53f0d-14c71bac@172.27.199.20|100 Trying
2023/11/28 13:37:22.365|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,14,263202.350^172.27.199.147^*|22756967|8b72ca80-56614172-53f0c-14c71bac@172.27.199.20|180 Ringing
2023/11/28 13:37:22.366|SIPT|28392015|UDP|OUT|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|5060|1,100,14,263202.350^172.27.199.147^*|22756968|62668A63-8D5C11EE-A00C9738-1F24A1A8@172.27.199.1|180 Ringing
2023/11/28 13:37:22.403|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.341^172.27.199.132^*|22756972|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|180 Ringing
2023/11/28 13:37:22.418|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,14,263227.300^172.27.199.122^*|22756973|8b72ca80-56614172-53f0e-14c71bac@172.27.199.20|180 Ringing
2023/11/28 13:37:22.422|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,14,263222.232^172.27.199.123^*|22756974|8b72ca80-56614172-53f0d-14c71bac@172.27.199.20|180 Ringing
2023/11/28 13:37:26.017|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.342^172.27.199.132^*|22756978|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|200 OK
2023/11/28 13:37:26.022|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,14,263193.342^172.27.199.132^*|22756982|8b72ca80-56614172-53f0c-14c71bac@172.27.199.20|CANCEL
2023/11/28 13:37:26.022|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,14,263193.342^172.27.199.132^*|22756983|8b72ca80-56614172-53f0d-14c71bac@172.27.199.20|CANCEL
2023/11/28 13:37:26.022|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,14,263193.342^172.27.199.132^*|22756984|8b72ca80-56614172-53f0e-14c71bac@172.27.199.20|CANCEL
2023/11/28 13:37:26.026|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.342^172.27.199.132^*|22756985|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|ACK
2023/11/28 13:37:26.027|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.342^172.27.199.132^*|22756986|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|SUBSCRIBE
2023/11/28 13:37:26.028|SIPT|28392015|UDP|OUT|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|5060|1,100,14,263193.342^172.27.199.132^*|22756987|62668A63-8D5C11EE-A00C9738-1F24A1A8@172.27.199.1|200 OK
2023/11/28 13:37:26.035|SIPT|28392015|UDP|IN|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|63995|1,100,10,1.926745^172.27.199.1^*|22756988|62668A63-8D5C11EE-A00C9738-1F24A1A8@172.27.199.1|ACK
2023/11/28 13:37:26.075|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,14,263227.302^172.27.199.122^*|22756993|8b72ca80-56614172-53f0e-14c71bac@172.27.199.20|200 OK
2023/11/28 13:37:26.077|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,14,263227.303^172.27.199.122^*|22756994|8b72ca80-56614172-53f0e-14c71bac@172.27.199.20|487 Request Cancelled
2023/11/28 13:37:26.077|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,14,263227.303^172.27.199.122^*|22756995|8b72ca80-56614172-53f0e-14c71bac@172.27.199.20|ACK
2023/11/28 13:37:26.089|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,14,263202.352^172.27.199.147^*|22756997|8b72ca80-56614172-53f0c-14c71bac@172.27.199.20|200 OK
2023/11/28 13:37:26.091|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,14,263202.353^172.27.199.147^*|22756998|8b72ca80-56614172-53f0c-14c71bac@172.27.199.20|487 Request Cancelled
2023/11/28 13:37:26.091|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,14,263202.353^172.27.199.147^*|22756999|8b72ca80-56614172-53f0c-14c71bac@172.27.199.20|ACK
2023/11/28 13:37:26.154|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,14,263222.234^172.27.199.123^*|22757001|8b72ca80-56614172-53f0d-14c71bac@172.27.199.20|200 OK
2023/11/28 13:37:26.154|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,14,263222.234^172.27.199.123^*|22757002|8b72ca80-56614172-53f0d-14c71bac@172.27.199.20|487 Request Cancelled
2023/11/28 13:37:26.155|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,14,263222.234^172.27.199.123^*|22757004|8b72ca80-56614172-53f0d-14c71bac@172.27.199.20|ACK
2023/11/28 13:37:26.155|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.343^172.27.199.132^*|22757003|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|200 OK
2023/11/28 13:37:26.194|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.344^172.27.199.132^*|22757005|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|NOTIFY
2023/11/28 13:37:26.195|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.344^172.27.199.132^*|22757006|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|200 OK
2023/11/28 13:37:44.721|SIPT|28392015|UDP|IN|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|63995|1,100,10,1.926746^172.27.199.1^*|22757016|62668A63-8D5C11EE-A00C9738-1F24A1A8@172.27.199.1|BYE
2023/11/28 13:37:44.723|SIPT|28392015|UDP|OUT|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|5060|1,100,10,1.926746^172.27.199.1^*|22757017|62668A63-8D5C11EE-A00C9738-1F24A1A8@172.27.199.1|200 OK
2023/11/28 13:37:44.723|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,10,1.926746^172.27.199.1^*|22757018|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|BYE
2023/11/28 13:37:45.837|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.345^172.27.199.132^*|22757019|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|200 OK
2023/11/28 13:37:45.838|CC|RELEASE|28392015|28392016|127
2023/11/28 13:37:45.839|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.345^172.27.199.132^*|22757020|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|SUBSCRIBE
2023/11/28 13:37:45.892|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.346^172.27.199.132^*|22757027|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|200 OK
2023/11/28 13:37:45.932|SIPL|28392016|TCP|IN|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.347^172.27.199.132^*|22757028|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|NOTIFY
2023/11/28 13:37:45.933|SIPL|28392016|TCP|OUT|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.347^172.27.199.132^*|22757029|8b72ca80-56614172-53f0b-14c71bac@172.27.199.20|200 OK
Failed Call
Message Details
GUID: 9b8aaa00-5661418d-53f15-14c71bac@172.27.199.20
MSG_LABEL: INVITE
MSGTAG: 22757032
CORRELATIONID: 1,100,10,1.926747^172.27.199.1^*
TIMESTAMP: 2023/11/28 13:37:49.370
Message In Log File
2023/11/28 13:37:49.361|SIPT|0|UDP|IN|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|63995|1,100,10,1.926747^172.27.199.1^*|22757030|728EE3E3-8D5C11EE-A0129738-1F24A1A8@172.27.199.1|INVITE
2023/11/28 13:37:49.362|SIPT|0|UDP|OUT|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|5060|1,100,10,1.926747^172.27.199.1^*|22757031|728EE3E3-8D5C11EE-A0129738-1F24A1A8@172.27.199.1|100 Trying
2023/11/28 13:37:49.365|CC|SETUP|28392018|28392019|2513634312|5827|5827
2023/11/28 13:37:49.370|CC|OFFERED|28392018|28392019|2513634312|5827|5827|PCP_SIP_Thomasville_GWY|SEP5486BC7E14DC
2023/11/28 13:37:49.370|SIPL|28392019|TCP|OUT|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,10,1.926747^172.27.199.1^*|22757032|9b8aaa00-5661418d-53f15-14c71bac@172.27.199.20|INVITE
2023/11/28 13:37:49.372|SIPL|28392019|TCP|OUT|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,10,1.926747^172.27.199.1^*|22757033|9b8aaa00-5661418d-53f16-14c71bac@172.27.199.20|INVITE
2023/11/28 13:37:49.373|SIPL|28392019|TCP|OUT|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,10,1.926747^172.27.199.1^*|22757034|9b8aaa00-5661418d-53f17-14c71bac@172.27.199.20|INVITE
2023/11/28 13:37:49.373|SIPL|28392019|TCP|OUT|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,10,1.926747^172.27.199.1^*|22757035|9b8aaa00-5661418d-53f18-14c71bac@172.27.199.20|INVITE
2023/11/28 13:37:49.376|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.348^172.27.199.132^*|22757036|9b8aaa00-5661418d-53f15-14c71bac@172.27.199.20|100 Trying
2023/11/28 13:37:49.376|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,14,263202.355^172.27.199.147^*|22757037|9b8aaa00-5661418d-53f16-14c71bac@172.27.199.20|100 Trying
2023/11/28 13:37:49.377|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,14,263222.236^172.27.199.123^*|22757038|9b8aaa00-5661418d-53f17-14c71bac@172.27.199.20|100 Trying
2023/11/28 13:37:49.378|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,14,263227.305^172.27.199.122^*|22757039|9b8aaa00-5661418d-53f18-14c71bac@172.27.199.20|100 Trying
2023/11/28 13:37:49.452|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.349^172.27.199.132^*|22757040|9b8aaa00-5661418d-53f15-14c71bac@172.27.199.20|180 Ringing
2023/11/28 13:37:49.455|SIPT|28392018|UDP|OUT|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|5060|1,100,14,263193.349^172.27.199.132^*|22757041|728EE3E3-8D5C11EE-A0129738-1F24A1A8@172.27.199.1|180 Ringing
2023/11/28 13:37:49.512|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,14,263202.356^172.27.199.147^*|22757042|9b8aaa00-5661418d-53f16-14c71bac@172.27.199.20|180 Ringing
2023/11/28 13:37:49.513|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,14,263227.306^172.27.199.122^*|22757043|9b8aaa00-5661418d-53f18-14c71bac@172.27.199.20|180 Ringing
2023/11/28 13:37:49.522|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,14,263222.237^172.27.199.123^*|22757044|9b8aaa00-5661418d-53f17-14c71bac@172.27.199.20|180 Ringing
2023/11/28 13:38:01.478|SIPT|28392018|UDP|OUT|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|5060|1,100,14,263193.349^172.27.199.132^*|22757060|728EE3E3-8D5C11EE-A0129738-1F24A1A8@172.27.199.1|480 Temporarily Not Available
2023/11/28 13:38:01.479|SIPL|28392019|TCP|OUT|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.349^172.27.199.132^*|22757061|9b8aaa00-5661418d-53f15-14c71bac@172.27.199.20|CANCEL
2023/11/28 13:38:01.479|SIPL|28392019|TCP|OUT|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,14,263193.349^172.27.199.132^*|22757062|9b8aaa00-5661418d-53f16-14c71bac@172.27.199.20|CANCEL
2023/11/28 13:38:01.479|SIPL|28392019|TCP|OUT|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,14,263193.349^172.27.199.132^*|22757063|9b8aaa00-5661418d-53f17-14c71bac@172.27.199.20|CANCEL
2023/11/28 13:38:01.479|SIPL|28392019|TCP|OUT|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,14,263193.349^172.27.199.132^*|22757064|9b8aaa00-5661418d-53f18-14c71bac@172.27.199.20|CANCEL
2023/11/28 13:38:01.486|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.350^172.27.199.132^*|22757065|9b8aaa00-5661418d-53f15-14c71bac@172.27.199.20|200 OK
2023/11/28 13:38:01.490|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,14,263202.357^172.27.199.147^*|22757066|9b8aaa00-5661418d-53f16-14c71bac@172.27.199.20|200 OK
2023/11/28 13:38:01.491|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,14,263222.238^172.27.199.123^*|22757067|9b8aaa00-5661418d-53f17-14c71bac@172.27.199.20|200 OK
2023/11/28 13:38:01.492|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,14,263227.307^172.27.199.122^*|22757068|9b8aaa00-5661418d-53f18-14c71bac@172.27.199.20|200 OK
2023/11/28 13:38:01.493|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.351^172.27.199.132^*|22757069|9b8aaa00-5661418d-53f15-14c71bac@172.27.199.20|487 Request Cancelled
2023/11/28 13:38:01.493|SIPL|28392019|TCP|OUT|172.27.199.20|5060|SEP5486BC7E14DC|172.27.199.132|50566|1,100,14,263193.351^172.27.199.132^*|22757074|9b8aaa00-5661418d-53f15-14c71bac@172.27.199.20|ACK
2023/11/28 13:38:01.493|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,14,263202.358^172.27.199.147^*|22757070|9b8aaa00-5661418d-53f16-14c71bac@172.27.199.20|487 Request Cancelled
2023/11/28 13:38:01.494|SIPL|28392019|TCP|OUT|172.27.199.20|5060|SEPC4B36ACB6874|172.27.199.147|50731|1,100,14,263202.358^172.27.199.147^*|22757075|9b8aaa00-5661418d-53f16-14c71bac@172.27.199.20|ACK
2023/11/28 13:38:01.494|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,14,263222.239^172.27.199.123^*|22757071|9b8aaa00-5661418d-53f17-14c71bac@172.27.199.20|487 Request Cancelled
2023/11/28 13:38:01.494|SIPL|28392019|TCP|OUT|172.27.199.20|5060|SEP00B1E3812948|172.27.199.123|50308|1,100,14,263222.239^172.27.199.123^*|22757076|9b8aaa00-5661418d-53f17-14c71bac@172.27.199.20|ACK
2023/11/28 13:38:01.494|SIPL|28392019|TCP|IN|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,14,263227.308^172.27.199.122^*|22757072|9b8aaa00-5661418d-53f18-14c71bac@172.27.199.20|487 Request Cancelled
2023/11/28 13:38:01.495|SIPL|28392019|TCP|OUT|172.27.199.20|5060|SEP04EB4060C8D8|172.27.199.122|50304|1,100,14,263227.308^172.27.199.122^*|22757077|9b8aaa00-5661418d-53f18-14c71bac@172.27.199.20|ACK
2023/11/28 13:38:01.495|SIPT|28392018|UDP|IN|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|63995|1,100,10,1.926749^172.27.199.1^*|22757073|728EE3E3-8D5C11EE-A0129738-1F24A1A8@172.27.199.1|ACK
2023/11/28 13:38:01.495|CC|RELEASE|28392018|28392019|41
Cause Code= 41 Temporary failure. The call was disconnected due to a network failure.
The logs you shared show a Temporarily Not Available message.
"13:38:01.478|SIPT|28392018|UDP|OUT|172.27.199.20|5060|PCP_SIP_Thomasville_GWY|172.27.199.1|5060|1,100,14,263193.349^172.27.199.132^*|22757060|728EE3E3-8D5C11EE-A0129738-1F24A1A8@172.27.199.1|480 Temporarily Not Available"
Please collect the debug CCSIP messages and the CUCM trace and share them with us. Before you get the trace from RTMT, enable the following settings in CUCM trace:
2.Check if the trace level is set to Detailed
Response Signature
Here is what I have
INVITE sip:5827@172.27.199.20:5060 SIP/2.0
Via: SIP/2.0/UDP 172.27.199.1:5060;branch=z9hG4bK84A42448
Remote-Party-ID: "INC,SWALNET" <sip:2513634312@172.27.199.1>;party=calling;screen=yes;privacy=off
From: "INC,SWALNET" <sip:2513634312@172.27.199.1>;tag=E0E3CCAC-11C5
To: <sip:5827@172.27.199.20>
Date: Wed, 29 Nov 2023 11:34:23 GMT
Call-ID: 2276A597-8E2511EE-A4E69738-1F24A1A8@172.27.199.1
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 0578081055-2384794094-2984591361-2057724816
User-Agent: Cisco-SIPGateway/IOS-15.5.3.M4a
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1701286463
Contact: <sip:2513634312@172.27.199.1:5060>
Expires: 180
Allow-Events: kpml, telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 429
v=0
o=CiscoSystemsSIP-GW-UserAgent 2175 834 IN IP4 172.27.199.1
s=SIP Call
c=IN IP4 172.27.199.1
t=0 0
m=audio 18826 RTP/AVP 0 18 8 116 100 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:8 PCMA/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=maxptime:20
SIP/2.0 100 Trying
Date: Wed, 29 Nov 2023 19:34:23 GMT
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
INVITE sip:b393ba3e-9236-dd0f-c2ff-c7473f215e38@172.27.199.122:50304;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.27.199.20:5060;branch=z9hG4bK10e57216468744
From: "INC,SWALNET" <sip:2513634312@172.27.199.20>;tag=7306454~c69babc2-1f28-43b7-b328-e68e432cdd38-28395694
To: <sip:5827@172.27.199.122>
Call-ID: 4b2b4f00-5671923f-54cfa-14c71bac@172.27.199.20
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM11.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Call-Info: <urn:x-cisco-remotecc:callinfo>; security= Unknown; orientation= from; gci= 1-1413745; isVoip; call-instance= 1
Send-Info: conference, x-cisco-conference
Alert-Info: <file://Bellcore-dr2/>
Session-ID: cc9ad076e5b9a4a8ea9d054ab7306453;remote=00000000000000000000000000000000
Remote-Party-ID: "INC,SWALNET" <sip:2513634312@172.27.199.20;x-cisco-callback-number=2513634312>;party=calling;screen=yes;privacy=off
Contact: <sip:2513634312@172.27.199.20:5060;transport=tcp>
Max-Forwards: 69
Content-Length: 0
INVITE sip:f717d588-83d9-2abd-a709-1ef3a64f63c6@172.27.199.123:51316;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.27.199.20:5060;branch=z9hG4bK10e57393ebf7
From: "INC,SWALNET" <sip:2513634312@172.27.199.20>;tag=7306455~c69babc2-1f28-43b7-b328-e68e432cdd38-28395694
To: <sip:5827@172.27.199.123>
Call-ID: 4b2b4f00-5671923f-54cfb-14c71bac@172.27.199.20
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 0
INVITE sip:3754a618-8ca9-1afe-7194-951f60183000@172.27.199.132:51461;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.27.199.20:5060;branch=z9hG4bK10e5743e18d28c
From: "INC,SWALNET" <sip:2513634312@172.27.199.20>;tag=7306456~c69babc2-1f28-43b7-b328-e68e432cdd38-28395694
To: <sip:5827@172.27.199.132>
Call-ID: 4b2b4f00-5671923f-54cfc-14c71bac@172.27.199.20
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 0
INVITE sip:2089441e-3837-d17d-aa27-6462ec4c4c5c@172.27.199.147:50204;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.27.199.20:5060;branch=z9hG4bK10e5754f5df89c
From: "INC,SWALNET" <sip:2513634312@172.27.199.20>;tag=7306457~c69babc2-1f28-43b7-b328-e68e432cdd38-28395694
To: <sip:5827@172.27.199.147>
Call-ID: 4b2b4f00-5671923f-54cfd-14c71bac@172.27.199.20
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 0
SIP/2.0 100 Trying
Session-ID: 245bb9df00105000a00004eb4060c8d8;remote=cc9ad076e5b9a4a8ea9d054ab7306453
CSeq: 101 INVITE
Server: Cisco-CP8851/12.7.1
Contact: <sip:76789175-0b9a-3369-70da-9748fd59876e@172.27.199.122:50304;transport=tcp>;+u.sip!devicename.ccm.cisco.com="SEP04EB4060C8D8"
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Content-Length: 0
Recv-Info: conference
Recv-Info: x-cisco-conference
SIP/2.0 100 Trying
Session-ID: 31904c3500105000a00000b1e3812948;remote=cc9ad076e5b9a4a8ea9d054ab7306453
CSeq: 101 INVITE
Contact: <sip:8a46e370-813f-854e-2a0b-1da0628343ce@172.27.199.123:51316;transport=tcp>;+u.sip!devicename.ccm.cisco.com="SEP00B1E3812948"
Content-Length: 0
SIP/2.0 100 Trying
Session-ID: 3d2f7ae200105000a0005486bc7e14dc;remote=cc9ad076e5b9a4a8ea9d054ab7306453
CSeq: 101 INVITE
Contact: <sip:ff3d2b00-772a-f202-3144-95abea8b6e1a@172.27.199.132:51461;transport=tcp>;+u.sip!devicename.ccm.cisco.com="SEP5486BC7E14DC"
Content-Length: 0
SIP/2.0 100 Trying
Session-ID: 185bce6b00105000a000c4b36acb6874;remote=cc9ad076e5b9a4a8ea9d054ab7306453
CSeq: 101 INVITE
Contact: <sip:5af9771c-beb1-3c38-9ce6-02afa125cfb7@172.27.199.147:50204;transport=tcp>;+u.sip!devicename.ccm.cisco.com="SEPC4B36ACB6874"
Content-Length: 0
SIP/2.0 180 Ringing
To: <sip:5827@172.27.199.147>;tag=c4b36acb6874002d62f1c6ad-103582f9
CSeq: 101 INVITE
Contact: <sip:2089441e-3837-d17d-aa27-6462ec4c4c5c@172.27.199.147:50204;transport=tcp>;+u.sip!devicename.ccm.cisco.com="SEPC4B36ACB6874"
Remote-Party-ID: "5827" <sip:5827@CUCM>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
SIP/2.0 180 Ringing
To: <sip:5827@172.27.199.20>;tag=7306453~c69babc2-1f28-43b7-b328-e68e432cdd38-28395693
CSeq: 101 INVITE
Server: Cisco-CUCM11.5
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "City Hall" <sip:5827@172.27.199.20>
Remote-Party-ID: "City Hall" <sip:5827@172.27.199.20>;party=called;screen=yes;privacy=off
Contact: <sip:5827@172.27.199.20:5060>;+u.sip!devicename.ccm.cisco.com="SEPC4B36ACB6874"
Content-Length: 0
SIP/2.0 180 Ringing
To: <sip:5827@172.27.199.132>;tag=5486bc7e14dc048a075d53a1-4f1fc6a6
CSeq: 101 INVITE
Contact: <sip:3754a618-8ca9-1afe-7194-951f60183000@172.27.199.132:51461;transport=tcp>;+u.sip!devicename.ccm.cisco.com="SEP5486BC7E14DC"
Remote-Party-ID: "3346365827" <sip:5827@CUCM>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
SIP/2.0 180 Ringing
To: <sip:5827@172.27.199.122>;tag=04eb4060c8d804680179e8ff-74857652
CSeq: 101 INVITE
Contact: <sip:b393ba3e-9236-dd0f-c2ff-c7473f215e38@172.27.199.122:50304;transport=tcp>;+u.sip!devicename.ccm.cisco.com="SEP04EB4060C8D8"
Content-Length: 0
SIP/2.0 180 Ringing
To: <sip:5827@172.27.199.123>;tag=00b1e3812948053e3599d315-19a777ce
CSeq: 101 INVITE
Contact: <sip:f717d588-83d9-2abd-a709-1ef3a64f63c6@172.27.199.123:51316;transport=tcp>;+u.sip!devicename.ccm.cisco.com="SEP00B1E3812948"
Content-Length: 0
SIP/2.0 480 Temporarily Not Available
CSeq: 101 INVITE
Content-Length: 0
CANCEL sip:b393ba3e-9236-dd0f-c2ff-c7473f215e38@172.27.199.122:50304;transport=tcp SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Session-ID: cc9ad076e5b9a4a8ea9d054ab7306453;remote=245bb9df00105000a00004eb4060c8d8
Content-Length: 0
CANCEL sip:f717d588-83d9-2abd-a709-1ef3a64f63c6@172.27.199.123:51316;transport=tcp SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Session-ID: cc9ad076e5b9a4a8ea9d054ab7306453;remote=31904c3500105000a00000b1e3812948
Content-Length: 0
CANCEL sip:3754a618-8ca9-1afe-7194-951f60183000@172.27.199.132:51461;transport=tcp SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Session-ID: cc9ad076e5b9a4a8ea9d054ab7306453;remote=3d2f7ae200105000a0005486bc7e14dc
Content-Length: 0
CANCEL sip:2089441e-3837-d17d-aa27-6462ec4c4c5c@172.27.199.147:50204;transport=tcp SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Session-ID: cc9ad076e5b9a4a8ea9d054ab7306453;remote=185bce6b00105000a000c4b36acb6874
Content-Length: 0
SIP/2.0 200 OK
Date: Wed, 29 Nov 2023 19:34:35 GMT
CSeq: 101 CANCEL
Content-Length: 0
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
Content-Length: 0
ACK sip:3754a618-8ca9-1afe-7194-951f60183000@172.27.199.132:51461;transport=tcp SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
CSeq: 101 INVITE
Content-Length: 0
ACK sip:2089441e-3837-d17d-aa27-6462ec4c4c5c@172.27.199.147:50204;transport=tcp SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
CSeq: 101 INVITE
Content-Length: 0
ACK sip:f717d588-83d9-2abd-a709-1ef3a64f63c6@172.27.199.123:51316;transport=tcp SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
CSeq: 101 INVITE
Content-Length: 0
ACK sip:b393ba3e-9236-dd0f-c2ff-c7473f215e38@172.27.199.122:50304;transport=tcp SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
ACK sip:5827@172.27.199.20:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
DEbug CCSIP All
Log Buffer (1000000 bytes):
002603: Nov 29 13:42:02.967: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3FFEDE74 with refCount = 1
002604: Nov 29 13:42:02.967: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3FFD67FC with refCount = 1
002605: Nov 29 13:42:02.967: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [172.27.199.20]:5060, local_address:[ - ]
002606: Nov 29 13:42:02.967: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3FFEDE74
002607: Nov 29 13:42:02.967: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
002608: Nov 29 13:42:02.967: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
002609: Nov 29 13:42:02.967: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
002610: Nov 29 13:42:02.967: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x3FFD67FC) counter, current msg->refCount = 2
002611: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.27.199.1:5060;branch=z9hG4bK84AEB2F
From: "INC,SWALNET" <sip:2513634312@172.27.199.1>;tag=E0F13C78-65E
To: <sip:5827@172.27.199.20>;tag=7307012~c69babc2-1f28-43b7-b328-e68e432cdd38-28395742
Date: Wed, 29 Nov 2023 21:41:50 GMT
Call-ID: F06BCDDF-8E3611EE-A5049738-1F24A1A8@172.27.199.1
CSeq: 101 INVITE
Session-ID: 7ed64bb100105000a00000b1e3812948;remote=cc9ad076e5b9a4a8ea9d054ab7307012
Content-Length: 0
002612: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Info/verbose/1024/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
002613: Nov 29 13:42:02.967: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentGTD: No GTD found in inbound container
002614: Nov 29 13:42:02.967: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3FFEDE74 with refCount = 1
002615: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Info/verbose/4096/sipSPIChangeDeferAckState: Change state from 0 to new state 0, called from :sipSPIPresendProcessing
002616: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 1 event
002617: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
002618: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
002619: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Info/info/4096/ccsip_offer_ans_handle_call_active:
002620: Nov 29 13:42:02.967: [0x231A0B14]CNFSM: cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_OFFER_SENT, event:E_SIP_DIALOG_ESTD
002621: Nov 29 13:42:02.967: [0x231A0B14]CNFSM: next_state:CNFSM_NO_STATE_CHANGE
002622: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Info/critical/1/ccsip_offer_ans_process_event: O/A - an event is deferred
002623: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Info/critical/4096/ccsip_offer_ans_event_defer: an event is deferred
002624: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Info/info/4096/sipSPISendAck: Associated container=0x23199424 to Ack
002625: Nov 29 13:42:02.967: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
002626: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
002627: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
002628: Nov 29 13:42:02.967: //51077/F06A958FB1EA/SIP/Transport/sipSPITransportSendMessage: msg=0x3FFEDE74, addr=172.27.199.20, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x0
002629: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
002630: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
002631: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
002632: Nov 29 13:42:02.971: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.27.199.20, rport:5060 with laddr:
002633: Nov 29 13:42:02.971: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x22B5E2E0 is already on connection=0x4164A1FC context_list
002634: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x3FFEDE74
002635: Nov 29 13:42:02.971: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3FFEDE74, addr=172.27.199.20, port=5060, local_addr=, connId=2 vrfid=0 for UDP
002636: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/critical/1024/act_recdproc_new_message_response: Received a 4/5/6xx message with StatusCode: 480
002637: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/verbose/4096/ccsip_set_release_source_for_peer: ownCallId[51077], src[4]
002638: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/verbose/4096/sipSPIUreasonHeader_to_ccCause: Cause=0
002639: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/critical/4096/sipSPIInitiateDisconnect: Initiate call disconnect(20) for outgoing call
002640: Nov 29 13:42:02.971: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3FFD15E8
002641: Nov 29 13:42:02.971: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentQSIG: No QSIG Body found in inbound container
002642: Nov 29 13:42:02.971: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentQ931: No RawMsg Body found in inbound container
002643: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 33
002644: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/critical/32768/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
002645: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/State/sipSPIChangeState: 0x22B5E2E0 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING) to (STATE_DISCONNECTING, SUBSTATE_NONE)
002646: Nov 29 13:42:02.971: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x3FFD67FC) counter, current msg->refCount = 1
002647: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/verbose/8192/ccsip_call_statistics: Requesting stats for callid=51077
002648: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/critical/8192/ccsip_call_statistics: Stats request failed for callid=51077, dstCallID=-1, rc=-7
002649: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 33
002650: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/critical/32768/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
002651: Nov 29 13:42:02.971: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
002652: Nov 29 13:42:02.971: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
002653: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/info/133120/sipSPIBwCacReleaseDialPeerBw: bwcac dial-peer bw 80 Kbps released for tag 200 active bw 0 Kbps
002654: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/info/131072/sipSPIBwCacReleaseInterfaceBw: bwcac releasing interface BVI1 bw 80 Kbps
002655: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/info/131072/sipSPIBwCacReleaseAccountedBw: bwcac released accounted bw 80000 bps
002656: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/info/4096/act_disconnecting_disconnect: Disconnect now.. no defer BYE..
002657: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/info/4096/sipSPISetCommonTimer: Started generic timer type 2 for 240000 millisecs
002658: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/verbose/8192/sipSPIDeferCallClose: Not split dataplane, bail
002659: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/verbose/8192/sipSPIWaitForStatsBforeCallClose: Not split dataplane, bail
002660: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/verbose/4096/sipSPICallCloseAfterFinalStat:
002661: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/info/12288/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:1236385280 ConnTime 0
002662: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Media/sipSPIHandleDestroyRtpSession: stream:3AA50C00
002663: Nov 29 13:42:02.971: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3FFD67FC
002664: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/State/sipSPIChangeState: 0x22B5E2E0 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
002665: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x22B5E2E0
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 2513634312
Called Number : 5827
Source IP Address (Sig 172.27.199.1
Destn SIP Req Addr:Port : 172.27.199.20:5060
Destn SIP Resp Addr:Port : 172.27.199.20:5060
Destination Name : 172.27.199.20
002666: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 172.27.199.1
Source IP Port (Media): 18830
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
002667: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 20
Disconnect Cause (SIP) : 480
002668: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id C785
002669: Nov 29 13:42:02.971: //51077/F06A958FB1EA/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Return and SIP_TIMER_REMOVE_TRANSACTION timer will free this ccb=0x22B5E2E0
002670: Nov 29 13:42:02.975: //51077/F06A958FB1EA/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 29 Nov 2023 13:41:50 GMT
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
002671: Nov 29 13:42:02.975: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3FFEDE74
BE6000S#
