06-10-2015 12:33 AM - edited 03-17-2019 03:17 AM
Hi Guys,
First post and a first time CUCM user so please be gentle with me! I'm looking to see if there is any way I can get a list of extensions, associated IP addresses and agent names. Ideally by logging into the CM CLI and grabbing the info?
Many Thanks
KFM
06-10-2015 04:58 AM
DNs are in CUCM's DB, dnorpattern table, IPs are not in any table, only on runtime memory, you can search previous threads on how to get that info, and agent name, assuming it's also configured in CUCM under description, or user association, you might also get it, if not, you'll need to get the report from UCC. But you're looking at the very least, to manually having to combine, at least, 2 separate reports to get the info.
06-10-2015 05:23 AM
Hi.
For Directory number and ip address association, you can login into cucm and issue the following command
show ridsb query phoneextn phone
this command will give you two info:
the state of ip phones (registered, unregistered) and their ip address
the status of directory number and their ip phone.
If on IP phone description , you specified the owner, than you will also have all info you need.
Carlo
