CUCM H323 Transfer issue
grnelis
I have CUCM 7.1.5 in the the US with a H323 gateway in Mexico.  When a call is transfered from an ip phone in Mexico to an external number out the same H323 gateway in Mexico the call is dropped.
The voice ccapi inout debug shows me the transfer number is NULL.  I tried using a MTP but that made call quality an all calls bad.
Any other ideas or suggestions is greatly appreciated.
5 Replies 5
hello,
This is usually a dial-peer problem ,
can you please give us a debug voice ccapi inout from your h323 gateway.
Make sure that the gateway has a CSS on the CUCM.
Amer
Ok, thanks here is the debug.  There are other calls in the debug.  I called to extension 53701 on my communicator from my cell of 803-667-1025 then transfered the call to 0448115162912.
Message was edited by: grnelis
you forgot to upload the debug.
Not sure what happened, it said up progress.  But it is there now.
Hi All,
I am having the same issue with calls. Tried the MTP method and that fixed the transfer but call quality was bad
Many thanks in advance for any assistance
Amre
