CUCM hold issue
kalashnikovsg
We are using CUCM 7.1 with Cisco 2901 15.2.1T as a CUBE. There is SIP trunk between CUCM and 2901, and another SIP trunk between 2901 and SIP provider. When we want to hold/transfer external call, which is coming from SIP provider, it is terminated. Internal calls have no issues.
In captured SIP traffic I see SIP INVITE to 0.0.0.0, 200 OK, ACK and then BYE from SIP provider. I tried configure "mid-call signaling block", but there is no any changes in behavior of CUBE. How can I fix this issue?
Sergey
32 Replies 32
Did you try 'midcall-signaling passthru' ? what is the disconnect cause code you see in the bye message? can you post the CUBE config and the debug messages pls?
//Suresh Please rate all the useful posts.
Yes, I tried "midcall-signaling passthru".
Config of CUBE:
version 15.2
voice-card 0
dsp services dspfarm
voice service pots
fax rate disable
voice service voip
  ip address trusted list
    ipv4 10.50.0.3 255.255.255.255
    ipv4 10.50.0.0 255.255.254.0
    ipv4 81.200.208.154 255.255.255.255
  dtmf-interworking rtp-nte
  allow-connections h323 to sip
  allow-connections sip to h323
  allow-connections sip to sip
  no supplementary-service h450.3
  supplementary-service h450.12
  no supplementary-service sip moved-temporarily
  no supplementary-service sip refer
  redirect ip2ip
  fax protocol t38 nse force version 0 ls-redundancy 2 hs-redundancy 2 fallback none
  h323
   emptycapability
  sip
   midcall-signaling passthru media-change
voice class codec 1
  codec preference 1 g711ulaw
  codec preference 2 g711alaw
  codec preference 3 g729r8
  codec preference 4 g729br8
voice class custom-cptone class1
  dualtone disconnect
   frequency 425
   cadence 500 1000
voice translation-rule 7
  rule 1 /2189/ /9791190/
voice translation-rule 9
  rule 1 /^9/ //
voice translation-rule 10
  rule 1 /.*/ /9791190/
voice translation-profile GOROD
  translate calling 10
  translate called 9
application
  service aatest flash:aatest.vxml
interface Loopback0
description -==Interface for SCCP application==-
   ip address 172.16.0.1 255.255.255.0
interface GigabitEthernet0/0
  description -== WAN ==-
  ip address 192.168.223.2 255.255.255.252
  duplex auto
  speed auto
interface GigabitEthernet0/1
  description -== LAN ==-
  ip address 10.63.0.1 255.255.255.0
  ip virtual-reassembly in
  duplex auto
  speed auto
ip route 0.0.0.0 0.0.0.0 192.168.223.1
tftp-server flash:aatest.vxml
tftp-server flash:vxml_allagentsbusy.au
tftp-server flash:vxml_disconnect.au
tftp-server flash:vxml_invalidoption.au
tftp-server flash:vxml_secretary_branch.au
tftp-server flash:vxml_welcome_sam.au
control-plane
voice-port 0/0/0
  supervisory disconnect dualtone mid-call
  supervisory custom-cptone class1
  cptone RU
  timeouts call-disconnect 1
  timeouts ringing 20
  timeouts wait-release 1
  timing hookflash-out 500
  connection plar opx 9791190
  description -==connection to PSTN1==-
  caller-id enable
voice-port 0/0/1
  cptone RU
  timeouts ringing 20
  connection plar opx 9791189
  description -==connection to PSTN2==-
caller-id enable
voice-port 0/0/2
  shutdown
voice-port 0/0/3
  shutdown
voice-port 0/1/0
  cptone RU
  description -==FAX==-
  station-id name Fax
  station-id number 2590
  caller-id enable
voice-port 0/1/1
  cptone RU
  description -==analog phone==-
  station-id name Sklad
  station-id number 2550
  caller-id enable
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 10.63.0.1 identifier 2 version 7.0
sccp ccm 10.50.0.3 identifier 1 version 7.0
sccp
sccp ccm group 2
bind interface GigabitEthernet0/1
associate ccm 2 priority 1
associate profile 1 register mtp28940fb887d1
switchover method immediate
switchback method immediate
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register XCODEsamara
dspfarm profile 2 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
dspfarm profile 1 transcode
codec g729br8
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
dial-peer voice 201 pots
destination-pattern 2590
fax rate disable
port 0/1/0
no sip-register
dial-peer voice 102 voip
description -==Incoming from SIP ==-
service aatest
session protocol sipv2
session target sip-server
incoming called-number 2189
voice-class sip dtmf-relay force rtp-nte
dtmf-relay sip-notify rtp-nte sip-kpml
codec g711ulaw
no vad
dial-peer voice 12 voip
description -==Outgoing to SIP ==-
translation-profile outgoing GOROD
preference 2
destination-pattern 9T
codec g711ulaw
no vad
dial-peer voice 202 pots
description -==Sklad Samara==-
destination-pattern 2550
port 0/1/1
no register e164
no sip-register
dial-peer voice 30 voip
description -==to internal numbers==-
destination-pattern [1245]...
session target ipv4:10.50.0.3
voice-class codec 1
no vad
sip-ua
credentials username 2189 password 7 133246025A595D7232121E realm 81.200.208.154:5060
authentication username 2189 password 7 1079580954424B5315321C
no remote-party-id
retry invite 3
retry register 10
timers connect 1000
registrar ipv4:81.200.208.154:5060 expires 1800
sip-server ipv4:81.200.208.154:5060
gatekeeper
shutdown
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 2
sdspfarm tag 1 mtp28940fb887d1
srst mode auto-provision none
srst ephone description Cisco SRST : Jul 02 2012 12:30:08
srst dn line-mode dual-octo
fxo hook-flash
max-ephones 25
max-dn 20
ip source-address 10.63.0.1 port 2000
timeouts interdigit 5
system message AKVATORIYA TEPLA
cnf-file location flash:
user-locale RU load CME-locale-ru_RU-Russian-8.1.2.1.tar
network-locale RU
network-locale 1 RU
network-locale 2 RU
network-locale 3 RU
network-locale 4 RU
time-zone 32
time-format 24
date-format dd-mm-yy
max-conferences 4 gain -6
call-forward pattern .T
moh "music-on-hold.au"
web admin system name zva password WebAdm
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern 2490 blind
Here is "debug ccsip mesages" and pcap dump from gateway with traffic from CUBE to SIP provider.
Hi Sergey,
I dont think the debug is complete.
If I understand correctly extn: 2189 called 4952874964 and tranffered the call to 2501. I dont see any Refer-to message in the debugs attached.
by the way, why there is "no supplementary-service sip refer"? can you try removing this and let me know how it works?
dont the service provider support Refer message?
in the debug I see CUBE received an INVITE message from CUCM with c=0.0.0.0 from the calling party 2501 and called party 4952874964. This indicates the Call Hold.
Oct 25 10:30:20.780: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4952874964@CCM-SBC IP-10.63.0.1:5060 SIP/2.0
Date: Thu, 25 Oct 2012 10:29:30 GMT
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: <2501>>;tag=2baadd03-a7b4-4f20-964a-6fbc9aec0881-21804043
Allow-Events: presence, kpml
P-Asserted-Identity: "Sinjakov Vladimir" <2501>
Supported: timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 3075301440-0499454434-2419700941-1776400203
Remote-Party-ID: "Sinjakov Vladimir" <2501>;party=calling;screen=yes;privacy=off
Content-Length: 238
User-Agent: Cisco-CUCM7.1
To: "4952874964" <4952874964>;tag=3622FFC-164D
Contact: <2501>
Expires: 180
Content-Type: application/sdp
Call-ID: BCA49098-1DC511E2-903FB4CD-69E1B74B@CCM-SBC IP-10.63.0.1
Via: SIP/2.0/UDP CUCM=10.50.0.3:5060;branch=z9hG4bK10f1f75bbf853
CSeq: 101 INVITE
Session-Expires:  1800;refresher=uac
Max-Forwards: 70
v=0
o=CiscoSystemsCCM-SIP 2000 2 IN IP4 CUCM=10.50.0.3
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
m=audio 23380 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=inactive
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
m=video 0 RTP/AVP 34
This call leg is disconnected with cause code 86 by CUCM as below
Oct 25 10:30:52.820: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:4952874964@CCM-SBC IP-10.63.0.1:5060 SIP/2.0
Reason: Q.850;cause=86
From: <2501>;tag=2baadd03-a7b4-4f20-964a-6fbc9aec0881-21804043
Content-Length: 0
Via: SIP/2.0/UDP CUCM=10.50.0.3:5060;branch=z9hG4bK10f234f7afee9
CSeq: 102 BYE
Max-Forwards: 70
Oct 25 10:30:52.824: //119165/B74D60409039/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4952874964@PSTN=81.200.208.154:5060 SIP/2.0
Via: SIP/2.0/UDP CUBE=192.168.223.2:5060;branch=z9hG4bK48842583
To: "4952874964" <4952874964>;tag=as0de60ebd
Date: Thu, 25 Oct 2012 10:29:51 GMT
Call-ID: 00b2276a7d11631d35dc6aff56af3e4e@PSTN=81.200.208.154
User-Agent: Cisco-SIPGateway/IOS-15.2(1)T1,
Max-Forwards: 70
Timestamp: 1351161052
CSeq: 102 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=2011,OS=321760,PR=3645,OR=579144,PL=0,JI=0,LA=0,DU=73
Content-Length: 0
Hi sureshsub2,
This is debug of failed hold. When call is placed on Hold, there is no any refer-to messages. May be I am wrong. I don't understand why after receiving INVITE with c=0.0.0.0, GW receives BYE message from CUCM.
Concerning incomplete debug, before making call, I run "debug ccsip messages" on GW. All messages were captured by router's buffer. I don't think that I missed any messages.
I can try to remove "no supplementary-service sip refer". But if I am not mistaken, this command take a part only during call transfer/forward.
May be it is better to capture debug of failed transfer?
Hi Sergey,
The Refer-To message is only for Call transfer not for Call Hold. The phone which put the call on hold will send the INVITE message with c=0.0.0.0 or a=sendonly.
From the given debugs, I could see two phones involved. one is 2189 and another one is 2501.
The phone with extn 2501 put the call of 4952874964 on Hold. CUCM sent the INVITE with c=0.0.0.0 to CUBE and then CUCM sends BYE message with cause code: 86. It indicates that the network has received a call  identity information element indicating a suspended call that has in the  meantime been cleared wile suspended.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/voice_troubleshooting/old/vts_appa.html#wp1007443
The BYE message sent from CUCM to CUBE is
Received:
Content-Length: 0
CSeq: 102 BYE
Max-Forwards: 70
But the CUBE sent another BYE message to PSTN with calling party number as 2901
Sent:
To: "4952874964" <4952874964>>;tag=as0de60ebd
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
The debug was from failed CALL HOLD? or Did the phone try to TRANSFER the call?
Is it possible to collect CUCM traces as well as debug ccsip all for a failed call again?
may be, we will come to know what is happening between CUCM and CUBE.
Let me know if you have any questions please
This debugs is CALL HOLD
Call flow is follow: SIP provider - IVR (2189) on CUBE - dial by extention (2501) - call hold
If you analyze pcap dump, you will see that BYE message was sent by SIP provider. It is very strange.
Also if I use "midcall-signaling passthru", CUBE should supress INVITE messages with c=0.0.0.0 to SIP provider.
I think that it will be difficult to callect loges from CUCM. It is simpler to capture traffic from CUCM to CUBE.
so you have configured AA in CUBE and that AA will transfer the calls to IP phones registered in CUCM.
Lets say, instead of direct internal calls, if one IP phone-A calls AA number (2189) and if AA transfers the call to another IP phone-B, is that working fine?
if the internal calls thru AA works fine, can you pls collect debug ccsip all and the packet capture for the external call issue?The previous pcap file was captured on 24th Oct and debug on 25th Oct.
To collect the detailed CCM SDI/SDL traces, please follow the link.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml#calm
also before collecting the debugs, can you pls try removing "no supplementary-service sip refer" and let me know how it works?
Message was edited by: Sureshsub2
I put command "supplementary-service sip refer", AA can't transfer any call.
I will try to collect. I have a little problem. If I turn "debug ccsip all" my router freeze. Of couse I collect debug only to buffer.
Looking at the logs the CUCM is sending a bye to the CUBE. Hence CUCM is disconnecting the call. You need to look at CUCM logs to see whats going on..
If you pull CUCM traces and attach it here I can look at it for you
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Therse are debuges and logs.
I called from  4952874964 to AA (2189) and then I was transfered by AA to 2599. After that I asked to transfer me. Call was terminated.
The calls do not exist in the CUCM trace. Please send the correct traces. Ensure you have detailed tracing enabled on your cucm. Ensure you are taking the trace from the CUCM server that the IP phone is registered to
Are you sure?
File "SDL001_100_000217.txt". Try to use ctrl-f "2599".
