07-18-2017 05:42 AM - edited 03-17-2019 10:49 AM
Dear Team,
We have CMS 1000 single server , we are planning to deploy skype for buisness, DO i need to get any additional licenes for integeration?
07-18-2017 09:59 AM
Not AFAIK, depending on the call flow, and devices involved, you'll use either SMP or PMP for the calls.
07-18-2017 10:09 AM
Dear Jaime,
I have below licenses..
LIC-TP-SMP-SL2SMP One SMP License on Conductor per Concurrent Meeting 3
07-18-2017 10:11 AM
Not sure if that's the right one, I'm talking about CMS licensing
http://www.cisco.com/c/en/us/products/collateral/conferencing/meeting-server/datasheet-c78-737519.html
07-18-2017 10:22 AM
Below is the list of license copied from BOM.
LIC-TP-SMP-SL2SMP One SMP License on Conductor per Concurrent Meeting 3 LIC-CMS-PAK Cisco Meeting Server (CMS) PAK 1 LIC-CMS-SMP-SL2SMP Cisco Meeting Server (CMS) SMP License for 1 Concurrent Meet 3 CON-PSBU-LICCPSL2 PSS SWSS UPGRADES Cisco Meeting Server 3 LIC-VMCNDTR-PMP-PK PAK for virtual Conductor
07-18-2017 11:41 PM
(as the text got mearge its difficult to understand how many of what)
To host a SFB calls you ll need normal PMP or SMP licences but with that make sure the Lync server can trust the Call Bridge certificate by uploading the Call Bridge Trusted CA certificate to the Root Trust Store of the Lync Servers. ( if you have a common CA for lync and call bridge certificate this is not required)
3 LIC-CMS-PAK -- Cisco Meeting Server (CMS) PAK for 3 CMS server.
3 CON-PSBU-LICCPSL2 PSS SWSS UPGRADES -- this is for 3 CMS server upgrade.
LIC-CMS-SMP-SL2SMP -- Cisco Meeting Server (CMS) SMP License for 1 Concurrent Meet
LIC-VMCNDTR-PMP-PK -- Virtual conductor
LIC-TP-SMP-SL2SMP -- for conductor licence for concorent meeting.
LIC-CMS-SMP-SL2SMP -- Cisco Meeting Server (CMS) SMP License for 1 Concurrent Meet ------ You will use this licencs on CMS for the meeting.
07-19-2017 01:07 AM
Thanks Prasad..
It's very clear the license usage.
07-18-2017 11:05 PM
Hi Siva,
You can check pages 10-13 of the following guide to understand the licensing requirements
http://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/Deployment_Guide/Version-2-0/Cisco-Meeting-Server-2-0-Single-Split-Server-Deployment.pdf
Manish
07-19-2017 06:55 AM
Thanks Maneesh ,
Will look into that.
