CUCM LDAP clear text AD user information
anish.mammen
CUCM version 11.5 with LDAP integration on port 389.
AD team has noticed that CUCM is sending end user credentials in clear text towards AD servers.
Is it because LDAPS(secured) is not enabled or there could be any other reasons for this.
Please let me know if you are aware of this issue.
Faraz Siddiqi
Jaime Valencia
Yes, that's because you're not using secure LDAP, that's the expected behavior.
java
if this helps, please rate
