CUCM - LDAP Problem
jotaanne
Hello Guys,
We have a CUCM Cluster with Version 12.0.1.22900-11 and We are having problems synchronizing our AD with our CUCM. I tried to sync and it supposedly syncs immediately but in reality it is not syncing.
I send the log file here so someone can try to help.
I already trying stop and started DIRSYNC and still doesn´t work.
9 Replies 9
You may have hit the bug CSCuz91655. Your version of CUCM is not on the "fixed in version" list. Check with TAC.
Exception while performing sync using secure port in LDAP directory pagehttps://bst.cisco.com/bugsearch/bug/CSCuz91655
Unfortunately, the fix seems to be upgrade or disable secure LDAP.
Maren
Thank u for the fast Reply Maren,
Is there a way to only disable secure LDAP for Call Manager? We only work with secure LDAP, so i need a way to just have the Call Manager without secure LDAP or another solution without upgrading the CUCM or disable secure LDAP if exists.
If you mean is there a way for MS-AD to selectively allow non-secure LDAP connections, I don't know. Someone else here may know, but you may have better luck posting that query in a Microsoft forum.
I would check with TAC first, regardless, in case my analysis is incorrect.
Maren
Vaijanath Sonvane
Hi @jotaanne,
Was this setup working before? Are there any changes made to the environment that broke the synchronization?
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Yes it worked! I really don't know. I only know that we started using Secure LDAP in our AD and TLS v1.3.
Hi @jotaanne,
CUCM 12.0 supports TLS 1.0, TLS 1.1, and TLS 1.2.
TLS version 1.3 is only supported in CUCM Release 15SU2 Onwards.
In this case you have three options:
  1. Update your LDAP to allow earlier TLS versions
  2. Update your LDAP to allow non secure connection from CUCM
  3. Upgrade you CUCM to 15SU2
Sorry for the misunderstanding. I went to talk to those responsible for our LDAP and they say they are using TLS v1.2 or higher. So, that's supposedly not the problem. IDK
Edward Lau
Have you confirmed the certificates of the LDAP server(s) are trusted by the UCM (tomcat-trust)?
Yes and they are.
