09-17-2013 09:07 AM - edited 03-16-2019 07:25 PM
Hello All,
maybe I'm missing some points and you can send me to some links with all the info required.
How can I do to migrate my old licenses from callmanager 8.0.3 to callmanager 9.1.2.
I'm looking for a kind of step-by-step guide.
I restored my DRSed system on a virtual hw.
Now ELM is not linked to the callmanager system.
I think I must attach the CM to the ELM.
How can I do to import the old licenses to the ELM?
I have this license: ucm-pak. Is it right?
I'm getting completly crazy with this upgrade procedure.
Any help is much appreciated.
thanks
lorenz
09-17-2013 09:29 AM
You need to get in touch with licensing (licensing@cisco.com) for this matter.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-17-2013 09:30 AM
You can refer the links
https://communities.cisco.com/docs/DOC-33806
https://communities.cisco.com/docs/DOC-30825
regds,
aman
