CUCM Media paths
sofiane__
We have CUCM v12.5. I know that by default CUCM is not involved in a call after the call has been set up. My question: is there a way to configure media paths (RTP audio) the same as signaling paths, I mean the media exchange doesn't occur directly between the IP Phones but through the CUCM.
Thank you in advance
Sofiane
Jaime Valencia
Yes, but you would need to use TRPs/MTPs and that doesn't scale with CUCM, you would need external resources on an ISR.
java
if this helps, please rate
Jaime Valencia
java
