CUCM MGCP FXO cptone config lost after GW restart
Marc El Achkar
I have a CUCM: 8.6.2.20000-2, with a 2901 MGCP gateway Version 15.1(4)M4, RELEASE SOFTWARE (fc1).
Everytime i restart the GW all the cptone configs i made a resetted to default for ex:
voice-port 0/2/1
supervisory disconnect dualtone mid-call
input gain 3
output attenuation -1
echo-cancel coverage 32
cptone KW
timeouts initial 5
timeouts interdigit 3
timeouts call-disconnect 2
timeouts wait-release 2
timing hookflash-out 50
After the restart it becomes
voice-port 0/2/1
input gain 3
timeouts initial 5
As we can see the cptone is lost.
Is there a solution to it ? or  a way that i can configure the cptone from the CUCM to be KW.
Best regards.
Craig Dyer
Level 3
Level 3
Marc,
     On the MGCP endpoint configuration is the 'Network Locale' set to 'Kuwait'
Hope this helps,
Craig
(PLEASE RATE HELPFUL POSTS)
Craig Dyer
Level 3
Level 3
Marc,
Hope this helps,
Craig
