12-26-2011 09:15 AM - edited 03-16-2019 08:42 AM
Hello All,
I am using Cisco call manager 6.0 and i am using public IP on it.I configure it well now my phone are registered from every network but i have one problem that my voice is going but i can't hear the another side voice. On my router or switch m not using any voice vlan or any rule so please advise me how to solve this problem ?
thanks
Mukesh
12-28-2011 06:15 AM
Temporary give 192.168.1.119 to some PC/Laptop and try ping\trace 117.199.123.15
You will see where packets stop.
I'm sure it is routing based problem.
Everything is ok with your configuration i think.
I faced with same problem in our first branch installation.
If you have no routes to all Phone's subnets.You'll not be able to make 2 way calls.
12-28-2011 08:09 AM
Hello D,
Yes you are right i have some packet drop when i do to tracert.but my public ip is advertised good and i can ping and trace it from any where and my "sh ip route" is also good.
So want i can do for it please advise me .
Mukesh
12-28-2011 08:24 AM
What is doing the topology hiding? Sounds as if signaling is fine, but your rtp traffic is going else where.
12-28-2011 09:09 PM
Login to your problem Phone by http and paste here last of console logs please
It will be named like: "/FS/cache/logXX"
12-29-2011 07:32 PM
Seems like he has a nat issue?? public ip into private you have any firewalls between networks?
