CUCM Overlap dialplan issue
eddy diddus
Hi, I have encountered a big problem with my dialplan. I'll try to explain briefly. In my country (Italy) there are 9-digit numbers, 10-digit numbers and 11-digit numbers and they all start with 0. My dialplan  is for 9 digit "0[1-8][1-6]XXXXXX" ,                        for 10 digit  "0[1-8][1-6]XXXXXXX" , and for 11 digit "0[1-8][1-6]XXXXXXXX" but doesn't work. I tried "0!" but the calls starts with a 12-second delay although my t302 is 3000. Someone has a solution for this issue? Thank you.
Chances are less that your ISP using a conflict dial plan. I never seen such a dial plan from ISP that first three digit are same.
Check again, instead of the mentioned dial plan  i believe there will be an option to make a precise dial plan.
When checking internet mobile numbers are starting with 3 and there "0" is not required.
Can you provide us your countries numbering plan if possible.
Response Signature
eddy diddus
Thank you for your answer. As you can see at https://it.wikipedia.org/wiki/Prefissi_telefonici_italiani all our numbers starts with 0. Some examples are 0816539984, 06734863122, 025865290, 0660513445, etc.
Share the numbers as mentioned below.
Landline
Mobile
National
Toll Free
Response Signature
