CUCM OVF template
adamgibs7
Level 6
Level 6
Dears,
Please find the attached snapshot for the OVF template,
i am using cucm_8.6_vmv8_v1.5.ova when i choose 1000 node it uses 2 vCPU and when i use 2500 user nodes it uses only 1 cpu why that's so when the no's of users are increasing the cpu should also increase.
thanks
Rob Huffman
Hi Adam,
Please see this note form the docwiki (for CUCM 8.6 ova);
Notes on 2500 user VM configurations
NoteNote:The 2500 user VM configuration with one vcpu may exhibit performance issues during CPU/IO-intensive operations (such as installs, upgrades, backups and CDR writes), or if your deployment has certain characteristics such as a large quantity of TFTP files. Changing the VM config to 2 vcpu is recommended as a prevention strategy. Otherwise you may deploy with one vcpu and be TAC-supported, but note that if the root cause of performance issues is found to be insufficient vcpu, Cisco TAC will ask that you change this to 2 vcpu. If your deployment is not experiencing any issues you are not required to change to 2 vcpu and may remain on 1 vcpu.
  • Use for publishers, subscribers, standalone TFTP, standalone multicast MOH nodes.ELM or PAWS-M
  • User count based on:
    • 1 device per user
    • 2.5K phones per VM
    • 10K max phones per cluster
    • 15K max BHCC per VM
    • 60K max BHCC per cluster
    • Your design/results may vary
From;
http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_Unified_Communications_Manager_(CUCM)#Notes_on_2500_user_VM_configurations
Cheers!
Rob
Rob Huffman
Hi Adam,
    • 1 device per user
From;
Cheers!
Rob
