CUCM phone numbers that not in use
deepfree1
Guys hello.
I need your assist please. Need get info from CUCM about the phone numbers (users) that are now disconnected and not in use.
4000 + users and its a little hard to make it one by one. Is there any options or plugins for CUCM so i can make it happen (in ?
I was trying with Unassigned DN phone number - doesnt help me.
I was trying with CAR CUCM - also nothing.
Need detail explanation please
P.S. reading forums doesnt gives me info i need.
Thanks in advance!
Rajan
In Route plan report, selecting unassigned DN option can give you the directory numbers which are not in use and not associated with any devices. Can you tell us what is your exact requirement? if you want to know the registered phone extensions which are not used for some time, i am not sure whether that is possible. You could probably get the CDR records for a duration and check for those extensions manually.
Rajan
He already asked this yesterday, but it seems he wants an easy way to find this out.
https://supportforums.cisco.com/discussion/13288921/cisco-call-manager-cucm
CDR will give you information on what DNs ARE MAKING CALLS, you need to get the full list of DNs you have available, or have configured in CUCM (dial plan report) and do this by matching which DNs are making calls, which ones are BEING USED, the ones you can't find in the reports, you can assume are not being used. But, this is something you need to do manually.
CDR/CAR can only keep records for up to 6 months, assuming it was configured that way, and that you're not reaching the maximum size for the DB, which causes the records to be deleted, even if they're not 6 months old yet.
java
if this helps, please rate
