CUCM publisher and Subscriber database replication bandwidth and time required.
achilles1417
Hi All,
Just want to get the information as title.
If one Publisher is placed in data center, and other Subscriber is placed in the remote location through MPLS (2M)
Can anyone tell me what is the time taking for the publisher and subscriber database replication and the total bandwidth required for the database replication?
Thank you,
Sunny Wong
Suresh Hudda
Hi Sunny,
40 msec one way (80 msec round trip) latency you need to maintain between publisher and subscriber, and 2 mb link is okay per node if above mentioned latency maintained.
Suresh
Hi Suresh,
Thank you for your reply.
But I think 2 M is too much.
Because there are only 2M for client MPLS between HQ and remote location.
It should be use for voice and Publisher and subscriber traffic.."
Jaime Valencia
The SRND already covers this
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab11/collab11/models.html#pgfId-1043996
There is no real way to tell you how long it will take, as with any other data transfer, it will depend on the network (speed, rtt, etc.), and the amount of data. Also explained in the above doc.
java
if this helps, please rate
Hi Jaime,
Thank you so much.
I am reading :-)
