Showing results forĀ
Search instead forĀ
Did you mean:Ā
CUCM rhosts and Presence server
aalejo
Level 5
Level 5
After integrating Presence server with CUCM, rhosts file dont match across the cluster. Some servers have the presence servers on the rhosts file  but others don't.
Any Ideas?
Leonardo Santana
Hello try to restart the servers.
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
That works for a CUCM cluster and for all servers that belong to that cluster. Not sure it will work on a Presence server that dont belong to the cluster.
Jaime Valencia
Only the PUB needs to know about CUPS, if the SUBs do not have it, there's no problem and I believe it's just a cosmetic bug
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
in fact you dont see the Presence server entry on the CUCM publisher server (rhosts). It is on some of the CUCM subscribers.
