cucm servicability account
Paul Austin
Level 4
Level 4
Hi All, Got a cucm cluster with connection and uccx - all works fine but we had an AD issue and now the Unified servicabilty account is locked out. I can log into every other account on every other server but just not this account. Is there a way to reset this password - the normal Administrator account is fine - they share the same password
Limitless1801
I am not sure what CUCM version are you running but the Serviceability account username and password is the same as the Administration one. If you can login into the Cisco Unified CM Administration, I don't see a reason why it doesn't work.
Take a look at this document that explains how to do so:
https://supportforums.cisco.com/docs/DOC-16780#_Reset_Application_password_on_CUCM_6
RG
