02-15-2011 01:53 PM - edited 03-16-2019 03:28 AM
I try to use dns for balancing and fault tolerance third-party SIP phones (e.g. x-lite).
I've configured dns with srv records
IN NAPTR 90 50 "s" "SIP+D2T" "" _sip._tcp.sip.domain.com.
IN NAPTR 100 50 "s" "SIP+D2U" "" _sip._udp.sip.domain.com.
sip 3 IN A 10.2.1.3
3 IN A 10.2.1.4
_sip._udp SRV 1 1 5060 sip.domain.com.
_sip._tcp SRV 1 1 5060 sip.domain.com.
10.2.1.3 and 10.2.1.4 - two servers in CUCM cluster ver. 7.1.5
nslookup
Default Server: relay.domain.com
Address: 10.2.2.10
> set type=srv
> _sip._tcp.domain.com
Address: 10.2.2.10
_sip._tcp.domain.com SRV service location:
priority = 1
weight = 1
port = 5060
svr hostname = sip.domain.com
domain.com nameserver = ns.domain.com
domain.com nameserver = ns1.domain.com
sip.domain.com internet address =10.2.1.3
sip.domain.com internet address =10.2.1.4
Sip softphone registers with domain and getting incomming calls.When I try to make outbound call from sip-client, the resporse is - "user not found"
In CDRs, the termination cause "unallocated/unassigned number" and called number looks like 7777@domain.com.
Сall passes when I manually adding call manager address (7777@10.2.1.3 or 7777@10.2.1.4).
Has anyone tried this successfully or have suggestions for the problem?
Thanks!
02-15-2011 04:45 PM
I have DNS enabled on my call manager with a primary and secondary server. You can check by using the CLI command show network eth0 detail to see the DNS. If it is inactive try setting up the DNS on the call manager and see if that works.
02-15-2011 06:17 PM
I have only primary DNS on callmanager, but it's active.
02-15-2011 06:24 PM
Have you checked the forward and reverse DNS zones to ensure there are DNS records?
Was the DNS setup from the beginning or did you add the DNS after the initial installation of the call manager?
Have you tried restarting the call manager?
02-16-2011 12:50 AM
Forward and reverse DNS zones configured.
The DNS was configured with cluster installation. Reboot the server does not help.
May be smth in cucm configuration missing?
02-16-2011 01:06 AM
.....looks like you have sip.domain.com and the called number above doesn't match
I would check your DNS configuration as that is not working correctly.
have a look here http://www.netcraftsmen.net/component/content/article/70-unified-communications/294-using-dns-srv-records-for-cisco-cucm-and-cups.html
02-19-2011 01:23 PM
Thank you for your help, Steven.
I added my domain.com to CUCM Enterprise parameters "Cluster Fully Qualified Domain Name".That was my mistake.
Now it works!
