CUCM-SIP to ISP - Flight mode calls issue
nibinrodrigues
Dear All,
We are having CUCM running version 8.6 connected to Voice Gateway via sip Tunk and from Gateway to ISP SIP trunk
Issue - IP Phone is continiously ringing eventhough I put my cell phone/mobile in Flighmode or Switch off. I am expecting message from ISP like "The person your are trying to reach is not avilable".
ISP bring their testing system and in that we are getting these alerts but when connect back to our PABX its riniging like normal call.
dial-peer voice 100 voip
service ses
destination-pattern .T
redirect ip2ip
session protocol sipv2
session target XXXXXX
voice-class sip dtmf-relay force rtp-nte
dtmf-relay sip-notify rtp-nte
codec g711alaw
no vad
Nibin
10 Replies 10
Hi Nibin,
did you configure a call forward or a remote destination to let your mobile ring?
Let me know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Dear Carlo,
My issue is that eventhogh the remote end is not accessable ie Switch off or in flight mode, still the IP Phone rings and user feels the remote party is not answering his call.
there is no configuration made for call forward.
Dear Nibin,
Understand.
As suggested from my buddy Vivek :) we need a debug ccsip message output to better analyze your issue.
Carlo
Dear Vivek/Carlo,
Please find below the attached ccsip message.
Customer number: 40004577
My mobile in number 55004439 (in flight mode)
We also requested ISP to check the issue from their end and they bring their PABX test system and found no issues. They where getting message like "The person you are trying to reach is not avilable"
Nibin
Hi Nibin,
This is one of the worst SDP negotiation I've ever seen.
Anyway, enable SDP early offer in CUBE and probably it will solve the issue. If not, request you to again share the output of debug ccsip messages after making appropriate changes.
voice server voip
 early-offer forced
- Vivek
Dear All,
Sorry for the long delay. Customer only provide me the maintenance window today.
As you advised, I enabled early-offer forced under sip, But the result is same. I am attaching my VG configuration and debug output 1 more more.
Nibin
From the logs we can see that your ITSP is sending media in the 183 session progress. We need to try and enable PRACK on CUCM, to see if the announcement that is being played comes through..
Go to the sip profile assigned to the sip trunk and under trunk specific configuration>>Send PRACK if 1xx contains SDPRequired Field
Please rate all useful posts
Dear Ayodeji,
Thanks for the suggestion, I will apply the setting today and update you the status.
Hi Nibin,
Please follow the steps as suggested by Deji and share the results.
- Vivek
Vivek Batra
Nibin - Can you please share the output of debug ccsip messages?
- Vivek
