IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6101 Views
  • 14 replies
Hello, I changed in our customer  implementation the service parameter Local route group for redirected calls to  Local route group of original called, to solve the known issue with calls to forwarded numbers to mobile from another location going out...
irusanu77 by Level 1
  • 1815 Views
  • 5 replies
Dear All Kindly i have an issue with enable srst it is not work , we try to enable SRST in router 2901 and router license is  License Type: EvalRightToUseLicense State: Active, In UseEvaluation total period: 8 weeks 4 daysEvaluation period left: 8 w...
SS_MO7722 by Level 1
  • 1213 Views
  • 5 replies
Hi , What is the meaning when cisco CUBE has rport feild empty or has no value , for instance : Received: REGISTER sip:XX.XX.XX.XX;transport=UDP SIP/2.0Via: SIP/2.0/UDP 10.230.42.209:1028;branch=z9hG4bK-524287-1---95f6b53cbf63ec4a;rport Max-Forwar...
Hi all, I need to install a CUCM Cluster (pub and sub), CUC, CUP 10.x every week. Im using BE6K servers (ESXi 5.5). Installs need to be done every week or so (For training) any recommendation in how to do this? New install is just UC software, clean ...
Hello,  I have a client who has Polycomm VoIP phonse and I'll be deploying Cisco C3650 switches. The phones will be connected to ports on the C3650. I wanted to know if the same port configuration we use with the Cisco VoIP phonse can be used with o...
zekebashi by Level 4
  • 4227 Views
  • 7 replies
So here's my situation:  I have a Cisco 8945 registered with CUCM 11.0 and using SIP.  This phone has built-in video capabilities, which I have verified is working (I have 2 of them and when I call one from the other, both phones do video).  However,...
