CUCM - SIP Trunking - CUBE - VWIC E1 QSIG - TDM PBX
Hello Community, in section CUCM and CUBE I had try to find a Dokumentation they describe the szenario in the subject, but w/o success.
Szenario: CUCM - SIP Trunking - CUBE - VWIC E1 QSIG - TDM PBX.
Szenario: CUCM - SIP Trunking - Voice GW 29xx - VWIC E1 QSIG - TDM PBX.
Are this szenario´s supported?
Does anyone have experience with it?
Best Regards Armin
HTH, please rate all useful posts and right answers.
Hi Arim.
There is nothing special to do to setup basic call routing between CUMC (SIP or H323) and Third Party PBX  using sig through a voice Gateway.
Basically configure E1 controller and Serial interface to meet PBX Qsig requirements.
Usually what follows could be enough.
interface Serial0/0/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
no cdp enable
Than you have to setup sip trunk on  CUCM and dialpeers on VG both to PBX(POTS) and to CUCM (VOIP).
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hello Carlo, really thanks for your effort. It seems for me that no Cube Function is needed.
It is also TLS ans SRTP possible?
The VGW and CUCM could convert all QSIG Supplemetary Services and Feature to SIP?
Best Regards Armin
