08-27-2023 01:18 AM - edited 08-27-2023 02:33 AM
Hello ,
My customer want to register CUCM to smart account via proxy
with SSL Inspection not by pass .
Is it support ?
my CUCM version is 12.5
I can't find documentation with SSL Inspection.
Solved! Go to Solution.
08-28-2023 04:05 AM
The concept should be the same. You'd have to import the proxy certificate(s) into the applicable trust store in the UC system. Likely it would be the Tomcat trust store. Having that said it's not recommended to include this traffic in the SSL inspection. It would be much better if you could get the customer to either exclude it from the inspection or use an on-prem SSM system and have the systems connect to it instead of each one communicating directly with the cloud SSM.
08-27-2023 04:44 AM
what proxy you using -
below guide help you :
08-27-2023 11:07 PM
Hello, the link that you refer Catalyst not CUCM .
08-28-2023 04:05 AM
