CUCM SQL question
is there a way to do run sql select .... and show only first 5 or 10 lines ? Is there way to send break  when SQL select is running ?
Thank you
Jaime Valencia
run sql "whatever query you want" limit X
java
if this helps, please rate
nope it didn't work, also i tried with fecth command it didnt work too :( .. looks like its not clean postgresql ?
example: run sql select name,description,tkmodel from device limit 5
A syntax error has occurred.
admin:run sql select name,description,tkmodel,tkdeviceprotocol,fkdevicepool, fkenduser from device where name like 'SEP%' and fkenduser IS NULL limit 5
Works fine for me on 12.0
admin:run sql select name,description,tkmodel from device limit 5
name description tkmodel
Sample Device Template with TAG usage examples #FirstName# #LastName# (#Product# #Protocol#) 645
Auto-registration Template #FirstName# #LastName# (#Product# #Protocol#) 645
MTP_2 MTP_CUCM11PUB 110
CFB_2 CFB_CUCM11PUB 50
ANN_2 ANN_CUCM11PUB 126
java
ok, I know why, I read earlier that limit command works on ur , because i have v10.5 and my sql is old may not support that command, unfortunately.
I know its for different topic but you know the answer and u can help :
 is un-checking "Trace On" option under IM&P Serviceability for XCP services will cause any service interruption ?   DO i need to restart XCP router?
jabberd with xcp config manager is eating Vmemory 95% :( .
