CUCM SQL request EM and phones
Hi, what is the correct way to pull phones out which don't have EM logged in users ?
I am using "select fkdevice from extensionmobilitydynamic where logintime is NULL" , but not sure ...
Thank you
HARIS_HUSSAIN
Check if below helps
https://community.cisco.com/t5/ip-telephony-and-phones/extension-mobility-report/td-p/2965809
*** Please rate helpful post &; Mark "Accept as a Solution" if applicable
Haris
No my friend, my question is a little bit different.
