CUCM stuck to x3650M2 UEFI UPDATE execution success
cristian.munoz
Level 4
Level 4
Hi Guys
Due to a power failure, the CUCM got stuck when turning on:
x3650M2 UEIF UPDATE  execution success
The server is 7845I3. CUCM ver. 8.6
Any idea?
TIA
Cristian
Joseph Martini
Are you using the CUCM install media or the firmware update CD (FWUCD) to update the UEIF?  If you're not using the FWUCD try using that first before using the CUCM install media.
