CUCM support for multiple "ptime" in the same "m" line in SDP ?
gabrieleodone
Hi Everyone,
environment: CUCM 8.0.3.22900-5
I would like to know if CUCM supports, in a SIP/SDP offer, multiple "ptime" fields for each "m" line
Example:
1. A SIP device answers a SIP invite from the CUCM with a SIP 100, then SIP 180, then SIP "200 Ok"
The SIP "200 Ok" packet sent from the device to the CUCM contains SDP information, as follows:
Session Description Protocol
<...lines removed...>
            Media Description, name and address (m): audio 5004 RTP/AVP 96 97 9 8 0
                Media Type: audio
                Media Port: 5004
                Media Protocol: RTP/AVP
                Media Format: DynamicRTP-Type-96
                Media Format: DynamicRTP-Type-97
                Media Format: ITU-T G.722
                Media Format: ITU-T G.711 PCMA
                Media Format: ITU-T G.711 PCMU
            Media Attribute (a): rtpmap:96 L16/48000/1
            Media Attribute (a): ptime:4
            Media Attribute (a): rtpmap:97 MPA/90000
            Media Attribute (a): fmtp:97 layer=2;samplerate=48000;bitrate=160000;mode=single_channel
            Media Attribute (a): rtpmap:9 G722/8000/1
            Media Attribute (a): ptime:20
            Media Attribute (a): rtpmap:8 PCMA/8000/1
            Media Attribute (a): rtpmap:0 PCMU/8000/1
            Media Attribute (a): sendrecv
Note the many "ptime" values, depending on the media offered.
2. The CUCM answers with a SIP ACK packet with SDP information, choosing the "PCMU/8000/1" protocol, but accepting the *wrong* ptime value - it chooses the first ptime value presented, not the one related to the "PCMU/8000/1" protocol after "rtpmap:0 PCMU/8000/1"
            Session Description Protocol Version (v): 0
            Owner/Creator, Session Id (o): CiscoSystemsCCM-SIP 2000 1 IN IP4 10.0.205.10
            Session Name (s): SIP Call
            Connection Information (c): IN IP4 10.70.0.142
            Time Description, active time (t): 0 0
            Media Description, name and address (m): audio 20242 RTP/AVP 0
                Media Type: audio
                Media Port: 20242
I have found a Cisco document, which is not about CUCM but rather about IOS SIP support (http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfsip.html), stating
"Cisco SIP gateways present or respond to the a=ptime parameter in the SDP body of a SIP message. However, only one a=ptimeattribute is allowed per m-line block."
Therefore I would like to know if the said behavior is as expected and if it is documented anywhere.
Gabriele
Ayodeji Okanlawon
Gabriele,
From the link you provided, I had a look too and it looks like its only one packetization time that is supported in the media attribute. This is the reason why you see it responding with a=ptime:4 because it can only support one and its the first one it sees..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Yes that's correct but the said document is not about CUCM... I wanted to know if this behavior is also documented for CUCM.
Ok. I am not sure but to be on the safe side,  I will assume it will be the same..The sip stack on CUCM and CUBE is very similar..You may need to open a TAC case to confirm this
