IP Telephony and Phones
watch here Journey banner_1
Labels
     Hi All - I just want to expand HDS DB size in ICM 8.5 which can hold last 2 years data, Is there any Best pratices Guide to estimate the HDD capacity and Perfomance of SQL and roll back plan if any issue occurs.Request to share the same if any. ...
Is a transconding functionality with in a gateway (CUBE) would be manadatory if we are getting calls from the service provider (on a SIP trunk) through a-law and gateway is communicating to CM through u-law dial peer.Service Provider ---a-law----> CU...
rehan_uet by Level 1
  • 4234 Views
  • 10 replies
Hi all, In coming Call from SIP trunk through IPTSP is not matching inbound voip dialpeer. so i am unable to play IVR prompt for outside caller.Outbound calls are working fine.Topology:               sccp                   H323                       ...
Resolved! SIP and E1
  We need to run SIP and 2 X (E1) ISDN on the single router and route calls between these two connections simultaneously . We have an estimated calls of 120 among of which 80 calls may go via SIP and 40 calls may route via ISDN (E1) .Is this possible...
SJ SJ by Level 1
  • 580 Views
  • 1 replies
Hi,After finished installing the cluster, I have changes the dns for all servers (one pub and two Subs).Do I need to add domain name for it to work? if I do, is there any risk, regarding loosing certificate.I want my CUCM works with LDAP based on nam...
hamed1900 by Level 1
  • 1585 Views
  • 2 replies
