CUCM timer problem - 422 Session Timer too small
radoslav-drabik
Beginner
Beginner
Guys,
I am getting the Session timer too small message when calling to a proxy server.
I've gone through RFC 4028 and there is written that a new INVITE should be sent from the CUCM server back to the proxy server with a new (proposed) session-expiry timer. See the trace below (I have omitted some parts)
This is not happening in my case with CUCM 7.1.5. Do you know what the problem can be? Thank you.
INVITE sip:6xxx@x.x.x.x:5060 SIP/2.0
Date: Tue, 13 Mar 2012 13:21:06 GMT
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Expires: 180
Session-Expires:  1800
SIP/2.0 422 Session Timer too small
Min-SE: 3600
Server: Cisco-SIPGateway/IOS-12.x
ACK sip:6xxx@x.x.x.x:5060 SIP/2.0
CSeq: 101 ACK
5 Replies 5
acampbell
Advocate
Advocate
Have you tried adjusting the Min-SE on the CUCM
To configure CUCM to have a Minimum Session Expires time <= 3600:
1. Log in to CUCM.
2. Go to
System > Service Parameters.
3. Select
Server = current server e.g. " (Active)".
4. Select
Service = Cisco CallManager (Active).
5. Search for
SIP Min-SE Value and set it to 3600.
Alex
Regards, Alex. Please rate useful posts.
The same thing came to my mind too. But I am afraid that if I change the service paramter values I can run into a situation when calls with
Session-Expires: 1800 won't go through. I will try that in a lab and let you know.
Anyway I still don't understand why the CUCM server doesn't retry the request with adjusted values (MIN-se and Session-expires: 3600) as it's explained in the standard.
My current values:
SIP session expires timer:    1800 sec (by default)
SIP Min-SE Value:               1800 sec (by default)
Thank you.
Hello
I've tested the same scenario by means of CUCM 8.x and CUCM 7.x in a lab and it was working for me. Both versions have formed another INVITE message with adjusted timers.
I am going to open a TAC case for it and we will see.
Configuring min se timer on gateway won't solve the issue for you?
Router(config)# voice service voip
Router(conf-voi-serv)# sip
Router(conf-serv-sip)# min-se time
Karthik Sivaram
Enthusiast
Enthusiast
Hello Radoslav,
You could be running into this  CSCsa54423.
Hope this helps!
Karthik
Recognize Your Peers
