01-12-2017 08:43 AM - edited 03-17-2019 09:09 AM
I have a 3845 ISR with a Dual Port E1 VWIC, also on this router I have CME 8.6 up and running.
I have created the necessary dial peers to to go out of one port of the E1 card and come back in on the other port (simulating to the pstn).
Calls from both of my CUCM's are reaching the CME over the E1 just fine and audio RTP audio is working fine.
But the issue is when I try to call from CUCM to CUCM over the E1 the other phone rings just fine but when I pick up the call is dropped :
503 Service Unavailable
Could somebody take a look at the sh run below and the attached traces and tell me if I have missed something ?
Current configuration : 5464 bytes
! Last configuration change at 17:38:13 CET Thu Jan 12 2017 by admin
! NVRAM config last updated at 16:15:54 CET Wed Jan 11 2017 by admin
version 15.1
service timestamps debug datetime msec localtime year
service timestamps log datetime msec localtime year
service password-encryption
service sequence-numbers
hostname ISR3845
boot-start-marker
boot-end-marker
logging queue-limit 500000
logging queue-limit trap 500000
logging buffered 7500000
no logging console
no logging monitor
enable secret 5
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone CET 1 0
no network-clock-participate slot 1
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
dspfarm
dot11 syslog
ip source-route
ip cef
ip domain name LEAR.OVH
no ipv6 cef
isdn switch-type primary-net5
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip handle-replaces
sip
bind control source-interface Loopback0
bind media source-interface Loopback0
registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 ilbc
voice class h323 1
h225 timeout tcp establish 3
voice register global
mode cme
source-address 10.10.5.1 port 5060
max-dn 10
max-pool 5
load 7941 Firmware/7941SIP-942/SIP41.9-4-2SR2-2S
date-format D/M/Y
tftp-path flash:
create profile sync 0001675206117158
voice register dn 1
number 4001
name BR PHONE
voice register pool 1
id mac 001B.D47D.C0CD
type 7941
number 1 dn 1
username BR2phone1 password cisco
voice translation-rule 1
rule 1 /.*\(2...$\)/ /\1/
rule 2 /.*\(3...$\)/ /\1/
rule 3 /.*\(4...$\)/ /\1/
voice translation-profile STRIP
translate called 1
license udi pid CISCO3845-MB sn FOC13494SL6
username admin privilege 15 secret
controller E1 1/0/0
clock source internal
pri-group timeslots 1-5,16
controller E1 1/0/1
interface Loopback0
description BR2CME
ip address 10.10.5.1 255.255.255.0
interface Loopback2
description H323
ip address 10.10.7.1 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.7.1
interface GigabitEthernet0/0
ip address 10.10.1.80 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial1/0/0:15
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn incoming-voice voice
isdn outgoing display-ie
isdn outgoing ie redirecting-number
no cdp enable
interface Serial1/0/1:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip route 10.10.0.0 255.255.255.0 10.10.1.254
ip route 10.10.2.0 255.255.255.0 10.10.1.254
ip route 10.10.3.0 255.255.255.0 10.10.1.254
ip route 10.10.4.0 255.255.255.0 10.10.1.254
ip route 10.10.10.0 255.255.255.0 10.10.1.254
ip route 10.10.20.0 255.255.255.0 10.10.1.254
ip route 10.10.30.0 255.255.255.0 10.10.1.254
tftp-server apps41.9-4-2ES22.sbn
tftp-server cnu41.9-4-2ES22.sbn
tftp-server cvm41sip.9-4-2ES22.sbn
tftp-server dsp41.9-4-2ES22.sbn
tftp-server jar41sip.9-4-2ES22.sbn
tftp-server SIP41.9-4-2SR2-2S.loads
tftp-server term41.default.loads
tftp-server term61.default.loads
control-plane
voice-port 1/0/0:15
translation-profile incoming STRIP
voice-port 1/0/1:15
mgcp profile default
dial-peer voice 1 pots
direct-inward-dial
dial-peer voice 2 voip
destination-pattern 2...$
session target ipv4:10.10.1.50
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 3 voip
destination-pattern 3...$
session target ipv4:10.10.1.60
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 4 voip
destination-pattern 4...$
session target ipv4:10.10.5.1
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 5 pots
destination-pattern 003356531....$
direct-inward-dial
port 1/0/1:15
telephony-service
no auto-reg-ephone
max-ephones 10
max-dn 20 no-reg both
ip source-address 10.10.5.1 port 2000
max-redirect 5
system message BR2CME
cnf-file location flash:
load 7941 SIP41.9-4-2SR2-2S.loads
date-format dd-mm-yy
max-conferences 12 gain -6
web admin system name admin secret
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Jan 11 2017 13:52:54
ephone-dn 1 octo-line
number 4002 no-reg both
description +33565314002
ephone 1
mac-address 4E25.3030.C7BD
username "br2phone2" password cisco
type CIPC
button 1:1
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 0 0
password 7
logging synchronous
transport input ssh
scheduler allocate 20000 1000
ntp server 10.10.0.254
end
01-12-2017 09:53 AM
None of your voip dial peers are inbound dial peers, so you want to fix that first to make sure proper codec is used, etc. Add "incoming called-number ." to one of your voip dial peer.
Where do you see the 503 error as that would imply SIP error, yet your config is H323?
01-12-2017 10:33 AM
Sip 403 error was in RTMT.
So I just made another call from phone on cluster 1 to phone on cluster 2 and I have the same issue, here are the new dial peers :
voice class codec 1
voice class h323 1
direct-inward-dial
incoming called-number 2...$
voice-class codec 1
voice-class h323 1
no vad
incoming called-number 3...$
voice-class codec 1
voice-class h323 1
no vad
incoming called-number 4...$
voice-class codec 1
voice-class h323 1
no vad
direct-inward-dial
port 1/0/1:15
And here is the debug :
Clear logging buffer [confirm]
ISR3845#
ISR3845#
ISR3845#
ISR3845#
ISR3845#
ISR3845#
ISR3845#
ISR3845#
ISR3845#
ISR3845#
ISR3845#
ISR3845#
ISR3845#sh log
Syslog logging: enabled (0 messages dropped, 14 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 775 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 252 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (7500000 bytes):
000251: Jan 12 2017 19:28:52.127: %ENVMON-4-FAN_LOW_RPM: Fan 1 service recommended
000252: Jan 12 2017 19:28:52.127: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
000253: Jan 12 2017 19:28:52.127: %ENVMON-4-FAN_LOW_RPM: Fan 3 service recommended
000254: Jan 12 2017 19:28:56.147: H225.0 INCOMING ENCODE BUFFER::= 20B0060008914A000501401F004200520031002000500068006F006E00650020003200000000000000000000000000000000000000000000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E616765720031000106003366898645335080A9D2F8E8CA7187010011010A0A140300D50D800007000A0A013C06B8110080A9D2F8E8CA7187010011010A0A1403010001000100010010A00100140140B50000120D82040020040001030003000103
000255: Jan 12 2017 19:28:56.147:
000256: Jan 12 2017 19:28:56.147: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
h323-uu-pdu
h323-message-body setup :
protocolIdentifier { 0 0 8 2250 0 5 }
sourceAddress
h323-ID : {"BR1 Phone 2..."}
sourceInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
productId '436973636F43616C6C4D616E61676572'H
versionId '31'H
terminal
mc FALSE
undefinedNode FALSE
destinationAddress
dialedDigits : "0033565312002"
activeMC FALSE
conferenceID '80A9D2F8E8CA7187010011010A0A1403'H
conferenceGoal create : NULL
callType pointToPoint : NULL
sourceCallSignalAddress ipAddress :
ip '0A0A013C'H
port 1720
callIdentifier
guid '80A9D2F8E8CA7187010011010A0A1403'H
mediaWaitForConnect FALSE
canOverlapSend FALSE
multipleCalls FALSE
maintainConnection FALSE
h245Tunneling FALSE
nonStandardControl
nonStandardIdentifier h221NonStandard :
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '82040020040001030003000103'H
000257: Jan 12 2017 19:28:56.151: H225 NONSTD INCOMING ENCODE BUFFER::= 82040020040001030003000103
000258: Jan 12 2017 19:28:56.151:
000259: Jan 12 2017 19:28:56.151: H225 NONSTD INCOMING PDU ::=
value H323_UU_NonStdInfo ::=
callMgrParam
interclusterVersion 3
enterpriseID {}
000260: Jan 12 2017 19:28:56.151: //-1/80A9D2F80100/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=BR1 Phone 2
----- ccCallInfo IE subfields -----
cisco-ani=3002
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0033565312002
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
000261: Jan 12 2017 19:28:56.151: //-1/80A9D2F80100/CCAPI/cc_api_call_setup_ind_common:
Interface=0x682F9BFC, Call Info(
Calling Number=3002,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0033565312002(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=3, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=15
000262: Jan 12 2017 19:28:56.151: //-1/80A9D2F80100/CCAPI/ccCheckClipClir:
In: Calling Number=3002(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
000263: Jan 12 2017 19:28:56.151: //-1/80A9D2F80100/CCAPI/ccCheckClipClir:
Out: Calling Number=3002(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
000264: Jan 12 2017 19:28:56.151: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000265: Jan 12 2017 19:28:56.151: :cc_get_feature_vsa malloc success
000266: Jan 12 2017 19:28:56.151: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000267: Jan 12 2017 19:28:56.151: cc_get_feature_vsa count is 1
000268: Jan 12 2017 19:28:56.151: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000269: Jan 12 2017 19:28:56.151: :FEATURE_VSA attributes are: feature_name:0,feature_time:1925787680,feature_id:9
000270: Jan 12 2017 19:28:56.151: //15/80A9D2F80100/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=3002(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0033565312002(TON=Unknown, NPI=Unknown))
000271: Jan 12 2017 19:28:56.151: //15/80A9D2F80100/CCAPI/cc_process_call_setup_ind:
Event=0x70D25290
000272: Jan 12 2017 19:28:56.151: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 0033565312002
000273: Jan 12 2017 19:28:56.155: //15/80A9D2F80100/CCAPI/ccCallSetContext:
Context=0x72CB3A4C
000274: Jan 12 2017 19:28:56.155: //15/80A9D2F80100/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 15 with tag 3 to app "_ManagedAppProcess_Default"
000275: Jan 12 2017 19:28:56.155: //15/80A9D2F80100/CCAPI/ccCallProceeding:
000276: Jan 12 2017 19:28:56.155: //15/80A9D2F80100/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=5, Params=0x72CB4F5C, Progress Indication=NULL(0)
000277: Jan 12 2017 19:28:56.155: //15/80A9D2F80100/CCAPI/ccCheckClipClir:
000278: Jan 12 2017 19:28:56.155: //15/80A9D2F80100/CCAPI/ccCheckClipClir:
000279: Jan 12 2017 19:28:56.155: //15/80A9D2F80100/CCAPI/ccCallSetupRequest:
Destination Pattern=003356531....$, Called Number=0033565312002, Digit Strip=TRUE
000280: Jan 12 2017 19:28:56.155: //15/80A9D2F80100/CCAPI/ccCallSetupRequest:
Redirect Number=, Display Info=BR1 Phone 2
Account Number=BR1 Phone 2, Final Destination Flag=TRUE,
Guid=80A9D2F8-E8CA-7187-0100-11010A0A1403, Outgoing Dial-peer=5
000281: Jan 12 2017 19:28:56.155: //15/80A9D2F80100/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=3002
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0033565312002
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
000282: Jan 12 2017 19:28:56.155: //15/80A9D2F80100/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x71848324, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=3002,(Calling Name=BR1 Phone 2)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0033565312002(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=5, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
000283: Jan 12 2017 19:28:56.155: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000284: Jan 12 2017 19:28:56.155: :cc_get_feature_vsa malloc success
000285: Jan 12 2017 19:28:56.155: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000286: Jan 12 2017 19:28:56.155: cc_get_feature_vsa count is 2
000287: Jan 12 2017 19:28:56.155: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000288: Jan 12 2017 19:28:56.155: :FEATURE_VSA attributes are: feature_name:0,feature_time:1925787456,feature_id:10
000289: Jan 12 2017 19:28:56.155: //16/80A9D2F80100/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
000290: Jan 12 2017 19:28:56.155: //16/80A9D2F80100/CCAPI/ccCallSetContext:
Context=0x72CB4F0C
000291: Jan 12 2017 19:28:56.155: //15/80A9D2F80100/CCAPI/ccSaveDialpeerTag:
000292: Jan 12 2017 19:28:56.155: H225.0 OUTGOING PDU ::=
h323-uu-pdu
h323-message-body callProceeding :
protocolIdentifier { 0 0 8 2250 0 4 }
destinationInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
mc FALSE
undefinedNode FALSE
h245Address ipAddress :
ip '0A0A0701'H
port 19529
callIdentifier
multipleCalls FALSE
h245Tunneling FALSE
000293: Jan 12 2017 19:28:56.159: H225.0 OUTGOING ENCODE BUFFER::= 21C0060008914A00042800B500001240013C050100000A0A07014C49110C110080A9D2F8E8CA7187010011010A0A14030100010010800100
000294: Jan 12 2017 19:28:56.159:
000295: Jan 12 2017 19:28:56.171: //-1/CFBB0A728004/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=3002
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=2002
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
000296: Jan 12 2017 19:28:56.171: //-1/CFBB0A728004/CCAPI/cc_api_call_setup_ind_common:
Interface=0x68AEF69C, Call Info(
Called Number=2002(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
000297: Jan 12 2017 19:28:56.171: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000298: Jan 12 2017 19:28:56.171: :cc_get_feature_vsa malloc success
000299: Jan 12 2017 19:28:56.171: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000300: Jan 12 2017 19:28:56.171: cc_get_feature_vsa count is 3
000301: Jan 12 2017 19:28:56.171: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000302: Jan 12 2017 19:28:56.171: :FEATURE_VSA attributes are: feature_name:0,feature_time:1925787232,feature_id:11
000303: Jan 12 2017 19:28:56.171: //17/CFBB0A728004/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Called Number=2002(TON=Unknown, NPI=Unknown))
000304: Jan 12 2017 19:28:56.171: //17/CFBB0A728004/CCAPI/cc_process_call_setup_ind:
Event=0x70D25290
000305: Jan 12 2017 19:28:56.175: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 2002
000306: Jan 12 2017 19:28:56.175: //17/CFBB0A728004/CCAPI/ccCallSetContext:
Context=0x72CB63CC
000307: Jan 12 2017 19:28:56.175: //17/CFBB0A728004/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 17 with tag 0 to app "_ManagedAppProcess_Default"
000308: Jan 12 2017 19:28:56.175: //17/CFBB0A728004/CCAPI/ccCallProceeding:
000309: Jan 12 2017 19:28:56.175: //17/CFBB0A728004/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=2, Params=0x72CB78DC, Progress Indication=NULL(0)
000310: Jan 12 2017 19:28:56.175: //17/CFBB0A728004/CCAPI/ccCheckClipClir:
000311: Jan 12 2017 19:28:56.175: //17/CFBB0A728004/CCAPI/ccCheckClipClir:
000312: Jan 12 2017 19:28:56.175: //17/CFBB0A728004/CCAPI/ccCallSetupRequest:
Destination Pattern=2...$, Called Number=2002, Digit Strip=FALSE
000313: Jan 12 2017 19:28:56.175: //17/CFBB0A728004/CCAPI/ccCallSetupRequest:
Account Number=, Final Destination Flag=TRUE,
Guid=CFBB0A72-D82B-11E6-8004-64168D723270, Outgoing Dial-peer=2
000314: Jan 12 2017 19:28:56.175: //17/CFBB0A728004/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=3002
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=2002
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
000315: Jan 12 2017 19:28:56.175: //17/CFBB0A728004/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x682F9BFC, Interface Type=1, Destination=, Mode=0x0,
Called Number=2002(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2, Call Count On=FALSE,
000316: Jan 12 2017 19:28:56.175: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000317: Jan 12 2017 19:28:56.175: :cc_get_feature_vsa malloc success
000318: Jan 12 2017 19:28:56.175: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000319: Jan 12 2017 19:28:56.175: cc_get_feature_vsa count is 4
000320: Jan 12 2017 19:28:56.175: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000321: Jan 12 2017 19:28:56.175: :FEATURE_VSA attributes are: feature_name:0,feature_time:1925787008,feature_id:12
000322: Jan 12 2017 19:28:56.175: //18/CFBB0A728004/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
000323: Jan 12 2017 19:28:56.175: //18/CFBB0A728004/CCAPI/ccCallSetContext:
Context=0x72CB788C
000324: Jan 12 2017 19:28:56.175: //17/CFBB0A728004/CCAPI/ccSaveDialpeerTag:
000325: Jan 12 2017 19:28:56.179: H245 FS OLC OUTGOING PDU ::=
value OpenLogicalChannel ::=
forwardLogicalChannelNumber 1
forwardLogicalChannelParameters
dataType audioData : nonStandard :
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '436C65617243686964'H
multiplexParameters h2250LogicalChannelParameters :
sessionID 1
mediaControlChannel unicastAddress : iPAddress :
network '0A0A0701'H
tsapIdentifier 18901
silenceSuppression FALSE
000326: Jan 12 2017 19:28:56.179: H245 FS OLC OUTGOING ENCODE BUFFER::= 0000000C10B500001209436C65617243686964800B050001000A0A070149D500
000327: Jan 12 2017 19:28:56.179:
000328: Jan 12 2017 19:28:56.179: H245 FS OLC OUTGOING PDU ::=
dataType nullData : NULL
multiplexParameters none : NULL
reverseLogicalChannelParameters
t35CountryCode 181
t35Extension 0
manufacturerCode 18
sessionID 1
mediaChannel unicastAddress : iPAddress :
network '0A0A0701'H
tsapIdentifier 18900
network '0A0A0701'H
000329: Jan 12 2017 19:28:56.179: H245 FS OLC OUTGOING ENCODE BUFFER::= 400000060401004C10B500001209436C656172436869648012150001000A0A070149D4000A0A070149D500
000330: Jan 12 2017 19:28:56.179:
000331: Jan 12 2017 19:28:56.179: H450 OUTGOING PDU ::=
value CmnArg ::=
featureList
ssCFreRoutingSupported NULL
ssCTreRoutingSupported NULL
000332: Jan 12 2017 19:28:56.179: H450 OUTGOING ENCODE BUFFER::= 43000000
000333: Jan 12 2017 19:28:56.179:
000334: Jan 12 2017 19:28:56.179: H450 OUTGOING PDU ::=
value H4501SupplementaryService ::=
networkFacilityExtension
sourceEntity endpoint : NULL
destinationEntity endpoint : NULL
interpretationApdu discardAnyUnrecognizedInvokePdu : NULL
serviceApdu rosApdus :
invoke :
invokeId 10
opcode local : 85
argument {"43000000"}
000335: Jan 12 2017 19:28:56.183: H450 OUTGOING ENCODE BUFFER::= 60000110000A0001550443000000
000336: Jan 12 2017 19:28:56.183:
000337: Jan 12 2017 19:28:56.183: H225 NONSTD OUTGOING PDU ::=
version 1
protoParam qsigNonStdInfo :
iei 4
rawMesg '040288901803A98385280B4252312050686F6E65...'H
000338: Jan 12 2017 19:28:56.183: H225 NONSTD OUTGOING ENCODE BUFFER::= 60010100010480C7040288901803A98385280B4252312050686F6E6520326C06008133303032700580323030321CA09E8100036774640000009549414D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A5553492C726174652C632C642C632C310D0A544D522C30310D0A43504E2C30302C2C752C323030320D0A43474E2C30302C2C752C792C322C333030320D0A4350432C30390D0A4643492C2C2C2C2C2C2C792C0D0A4743492C63666262306137326438326231316536383030343634313638643732333237300D0A0D0A
000339: Jan 12 2017 19:28:56.183:
000340: Jan 12 2017 19:28:56.183: H225.0 OUTGOING PDU ::=
h323-uu-pdu
sourceInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
mc FALSE
undefinedNode FALSE
activeMC FALSE
conferenceID 'CFBB0A72D82B11E6800464168D723270'H
ip '0A0A0701'H
port 59206
callIdentifier
guid 'CFBB0A72D82B11E6801BFE2D70D2DADB'H
fastStart
'0000000C10B500001209436C6561724368696480...'H,
'400000060401004C10B500001209436C65617243...'H
multipleCalls TRUE
maintainConnection TRUE
symmetricOperationRequired NULL
h4501SupplementaryService
'60000110000A0001550443000000'H
h245Tunneling TRUE
nonStandardControl
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '60010100010480C7040288901803A98385280B42...'H
tunnelledSignallingMessage
tunnelledProtocolID
id tunnelledProtocolAlternateID :
protocolType "gtd"
messageContent
'49414D2C0D0A50524E2C6973646E2A2C2C4E4554...'H
tunnellingRequired NULL
000341: Jan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
000342: Jan 12 2017 19:28:56.187:
000343: Jan 12 2017 19:28:56.187: //16/80A9D2F80100/CCAPI/cc_api_call_proceeding:
Interface=0x71848324, Progress Indication=NULL(0)
000344: Jan 12 2017 19:28:56.191: H225.0 INCOMING ENCODE BUFFER::= 2180060008914A000522C0B50000120F436973636F43616C6C4D616E6167657200310110C01100CFBB0A72D82B11E6801BFE2D70D2DADB0100010010A00100100140B500001209820400000400010300
000345: Jan 12 2017 19:28:56.191:
000346: Jan 12 2017 19:28:56.191: H225.0 INCOMING PDU ::=
h323-uu-pdu
destinationInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
versionId '31'H
terminal
mc FALSE
undefinedNode FALSE
callIdentifier
multipleCalls FALSE
h245Tunneling FALSE
nonStandardControl
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '820400000400010300'H
000347: Jan 12 2017 19:28:56.191: H225 NONSTD INCOMING ENCODE BUFFER::= 820400000400010300
000348: Jan 12 2017 19:28:56.191:
000349: Jan 12 2017 19:28:56.191: H225 NONSTD INCOMING PDU ::=
callMgrParam
enterpriseID {}
000350: Jan 12 2017 19:28:56.191: //18/CFBB0A728004/CCAPI/cc_api_set_called_ccm_detected:
CallInfo(called ccm detected=TRUE ccmVersion 3)
000351: Jan 12 2017 19:28:56.191: //18/CFBB0A728004/CCAPI/cc_api_call_proceeding:
Interface=0x682F9BFC, Progress Indication=NULL(0)
000352: Jan 12 2017 19:28:56.195: H225.0 INCOMING ENCODE BUFFER::= 2380060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003101B0C0001100CFBB0A72D82B11E6801BFE2D70D2DADB0100010010A00100100140B500001209820400000400010300
000353: Jan 12 2017 19:28:56.195:
000354: Jan 12 2017 19:28:56.195: H225.0 INCOMING PDU ::=
h323-uu-pdu
h323-message-body alerting :
destinationInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
versionId '31'H
terminal
mc FALSE
undefinedNode FALSE
callIdentifier
multipleCalls FALSE
h245Tunneling FALSE
nonStandardControl
t35CountryCode 181
t35Extension 0
manufacturerCode 18
000355: Jan 12 2017 19:28:56.195: H225 NONSTD INCOMING ENCODE BUFFER::= 820400000400010300
000356: Jan 12 2017 19:28:56.195:
000357: Jan 12 2017 19:28:56.195: H225 NONSTD INCOMING PDU ::=
callMgrParam
enterpriseID {}
000358: Jan 12 2017 19:28:56.195: //18/CFBB0A728004/CCAPI/cc_api_set_called_ccm_detected:
000359: Jan 12 2017 19:28:56.195: //18/CFBB0A728004/CCAPI/cc_api_set_delay_xport:
CallInfo(delay xport=TRUE)
000360: Jan 12 2017 19:28:56.195: //18/CFBB0A728004/CCAPI/cc_api_call_alert:
Interface=0x682F9BFC, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
000361: Jan 12 2017 19:28:56.195: //18/CFBB0A728004/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
000362: Jan 12 2017 19:28:56.195: H225.0 INCOMING ENCODE BUFFER::= 28501900060008914A000500CFBB0A72D82B11E6801BFE2D70D2DADB10800100
000363: Jan 12 2017 19:28:56.195:
000364: Jan 12 2017 19:28:56.195: H225.0 INCOMING PDU ::=
h323-uu-pdu
h323-message-body notify :
callIdentifier
h245Tunneling FALSE
000365: Jan 12 2017 19:28:56.195: //18/CFBB0A728004/CCAPI/cc_api_set_called_ccm_detected:
000366: Jan 12 2017 19:28:56.195: //18/CFBB0A728004/CCAPI/cc_api_call_notify:
Data Bitmask=0x7, Interface=0x682F9BFC, Call Id=18
000367: Jan 12 2017 19:28:56.195: //17/CFBB0A728004/CCAPI/ccCallAlert:
000368: Jan 12 2017 19:28:56.195: //17/CFBB0A728004/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
000369: Jan 12 2017 19:28:56.199: //17/CFBB0A728004/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Ring Back,
Tone Direction=Network, Params=0x0, Call Id=17
000370: Jan 12 2017 19:28:56.199: //18/CFBB0A728004/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
CallInfo(ssCTreRoutingNotSupported=FALSE)
000371: Jan 12 2017 19:28:56.199: //17/CFBB0A728004/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=17
000372: Jan 12 2017 19:28:56.203: //16/80A9D2F80100/CCAPI/cc_api_call_alert:
Interface=0x71848324, Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255)
000373: Jan 12 2017 19:28:56.203: //16/80A9D2F80100/CCAPI/cc_api_call_alert:
000374: Jan 12 2017 19:28:56.203: //15/80A9D2F80100/CCAPI/ccCallAlert:
000375: Jan 12 2017 19:28:56.203: //15/80A9D2F80100/CCAPI/ccCallAlert:
000376: Jan 12 2017 19:28:56.203: //16/80A9D2F80100/CCAPI/cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
000377: Jan 12 2017 19:28:56.203: //15/80A9D2F80100/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=15
000378: Jan 12 2017 19:28:56.203: //16/80A9D2F80100/CCAPI/cc_api_get_called_ccm_detected:
000379: Jan 12 2017 19:28:56.203: //15/80A9D2F80100/CCAPI/cc_api_get_delay_xport:
CallInfo(delay xport=FALSE)
000380: Jan 12 2017 19:28:56.203: H450 OUTGOING PDU ::=
value CmnArg ::=
featureList
000381: Jan 12 2017 19:28:56.203: H450 OUTGOING ENCODE BUFFER::= 43000000
000382: Jan 12 2017 19:28:56.203:
000383: Jan 12 2017 19:28:56.203: H450 OUTGOING PDU ::=
invoke :
invokeId 12
opcode local : 85
000384: Jan 12 2017 19:28:56.203: H450 OUTGOING ENCODE BUFFER::= 60000110000C0001550443000000
000385: Jan 12 2017 19:28:56.207:
000386: Jan 12 2017 19:28:56.207: H225 NONSTD OUTGOING PDU ::=
version 1
iei 28
rawMesg '1C269E8100036774640000001B41434D2C0D0A50...'H
000387: Jan 12 2017 19:28:56.207: H225 NONSTD OUTGOING ENCODE BUFFER::= 60010100011C281C269E8100036774640000001B41434D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A
000388: Jan 12 2017 19:28:56.207:
000389: Jan 12 2017 19:28:56.207: H225.0 OUTGOING PDU ::=
h323-uu-pdu
destinationInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
mc FALSE
undefinedNode FALSE
ip '0A0A0701'H
port 19529
callIdentifier
multipleCalls FALSE
'60000110000C0001550443000000'H
h245Tunneling FALSE
nonStandardControl
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '60010100011C281C269E8100036774640000001B...'H
tunnelledProtocolID
protocolType "gtd"
messageContent
'41434D2C0D0A50524E2C6973646E2A2C2C4E4554...'H
000390: Jan 12 2017 19:28:56.207: H225.0 OUTGOING ENCODE BUFFER::= 23C0060008914A00042800B500001240013C050100000A0A07014C491B0C00110080A9D2F8E8CA7187010011010A0A14030100010011A810010E60000110000C00015504430000000100360140B50000122F60010100011C281C269E8100036774640000001B41434D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A224204677464011B41434D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A
000391: Jan 12 2017 19:28:56.207:
000392: Jan 12 2017 19:28:56.211: H225.0 OUTGOING PDU ::=
h323-uu-pdu
callIdentifier
h245Tunneling FALSE
000393: Jan 12 2017 19:28:56.211: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A00040080A9D2F8E8CA7187010011010A0A140310800100
000394: Jan 12 2017 19:28:56.211:
000395: Jan 12 2017 19:28:56.211: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : terminalCapabilitySet :
sequenceNumber 1
protocolIdentifier { 0 0 8 245 0 7 }
multiplexCapability h2250Capability :
maximumAudioDelayJitter 20
receiveMultipointCapability
multicastCapability FALSE
multiUniCastConference FALSE
mediaDistributionCapability
centralizedControl FALSE
distributedControl FALSE
centralizedAudio FALSE
distributedAudio FALSE
centralizedVideo FALSE
distributedVideo FALSE
transmitMultipointCapability
receiveAndTransmitMultipointCapability
mcCapability
centralizedConferenceMC FALSE
decentralizedConferenceMC FALSE
rtcpVideoControlCapability FALSE
mediaPacketizationCapability
h261aVideoPacketization FALSE
logicalChannelSwitchingCapability FALSE
t120DynamicPortCapability FALSE
capabilityTable
capabilityTableEntryNumber 27
capability receiveUserInputCapability : basicString : NULL
capabilityTableEntryNumber 38
capability receiveAudioCapability : genericAudioCapability :
capabilityIdentifier standard : { 0 0 8 1 1 11 }
collapsing
parameterIdentifier standard : 1
parameterValue unsignedMax : 20
capability receiveAudioCapability : g711Ulaw64k : 20
capabilityDescriptors
capabilityDescriptorNumber 1
simultaneousCapabilities
3,
38
27
000396: Jan 12 2017 19:28:56.219: H245 MSC OUTGOING ENCODE BUFFER::= 027001060008817500078013800014000100000100000100000CC0010001000280001A83011080002524300D200005000801010B010013001480000220C01300800101010002002500001A
000397: Jan 12 2017 19:28:56.219:
000398: Jan 12 2017 19:28:56.219: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : masterSlaveDetermination :
terminalType 60
statusDeterminationNumber 804
000399: Jan 12 2017 19:28:56.219: H245 MSC OUTGOING ENCODE BUFFER::= 01003C400324
000400: Jan 12 2017 19:28:56.219:
000401: Jan 12 2017 19:28:56.311: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 124
000402: Jan 12 2017 19:28:56.311: H245 MSC INCOMING ENCODE BUFFER::= 0270010600088175000A801380003C000100000100000101000CC00100010005800000860A0000070008824301030180000120C0138000020C001D60000700088171000001400C800402914002A2002B003200480042000580000385014080000485011080002B85015000800003000001000002010003000400002B
000403: Jan 12 2017 19:28:56.311:
000404: Jan 12 2017 19:28:56.311: H245 MSC INCOMING PDU ::=
sequenceNumber 1
protocolIdentifier { 0 0 8 245 0 10 }
maximumAudioDelayJitter 60
centralizedVideo TRUE
mcCapability
capabilityTable
capabilityTableEntryNumber 1
capability genericControlCapability :
capabilityIdentifier standard : { 0 0 8 323 1 3 1 }
capability receiveVideoCapability : genericVideoCapability :
capabilityIdentifier standard : { 0 0 8 241 0 0 1 }
maxBitRate 3200
collapsing
parameterIdentifier standard : 41
parameterValue booleanArray : 64
parameterIdentifier standard : 42
parameterValue unsignedMin : 43
parameterIdentifier standard : 3
parameterValue unsignedMin : 72
parameterValue unsignedMin : 5
capabilityTableEntryNumber 4
capability receiveAndTransmitUserInputCapability : dtmf : NULL
capabilityTableEntryNumber 5
capability receiveAndTransmitUserInputCapability : basicString : NULL
capabilityTableEntryNumber 44
capability receiveAndTransmitUserInputCapability : hookflash : NULL
capabilityDescriptorNumber 0
000405: Jan 12 2017 19:28:56.315: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
000406: Jan 12 2017 19:28:56.315: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
000407: Jan 12 2017 19:28:56.315: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : terminalCapabilitySetAck :
sequenceNumber 1
000408: Jan 12 2017 19:28:56.319: H245 MSC OUTGOING ENCODE BUFFER::= 218001
000409: Jan 12 2017 19:28:56.319:
000410: Jan 12 2017 19:28:56.319: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 3
000411: Jan 12 2017 19:28:56.319: H245 MSC INCOMING ENCODE BUFFER::= 218001
000412: Jan 12 2017 19:28:56.319:
000413: Jan 12 2017 19:28:56.319: H245 MSC INCOMING PDU ::=
sequenceNumber 1
000414: Jan 12 2017 19:28:56.319: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
000415: Jan 12 2017 19:28:56.319: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
000416: Jan 12 2017 19:28:56.319: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
000417: Jan 12 2017 19:28:56.319: H245 MSC INCOMING ENCODE BUFFER::= 2080
000418: Jan 12 2017 19:28:56.319:
000419: Jan 12 2017 19:28:56.319: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= response : masterSlaveDeterminationAck :
decision master : NULL
000420: Jan 12 2017 19:28:56.319: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
000421: Jan 12 2017 19:28:56.319: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
000422: Jan 12 2017 19:28:56.319: H245 MSC OUTGOING PDU ::=
decision slave : NULL
000423: Jan 12 2017 19:28:56.319: H245 MSC OUTGOING ENCODE BUFFER::= 20A0
000424: Jan 12 2017 19:28:56.319:
000425: Jan 12 2017 19:28:56.319: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : openLogicalChannel :
dataType audioData : g711Ulaw64k : 20
sessionID 1
network '0A0A0701'H
tsapIdentifier 17175
000426: Jan 12 2017 19:28:56.319: H245 MSC OUTGOING ENCODE BUFFER::= 030000000C6013800B050001000A0A0701431700
000427: Jan 12 2017 19:28:56.319:
000428: Jan 12 2017 19:28:56.319: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 25
000429: Jan 12 2017 19:28:56.319: H245 MSC INCOMING ENCODE BUFFER::= 030000000C60138010850001000A0A140340B3028003100040
000430: Jan 12 2017 19:28:56.319:
000431: Jan 12 2017 19:28:56.319: H245 MSC INCOMING PDU ::=
sessionID 1
network '0A0A1403'H
tsapIdentifier 16563
transportCapability
mediaChannelCapabilities
mediaTransport ip-UDP : NULL
000432: Jan 12 2017 19:28:56.323: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
000433: Jan 12 2017 19:28:56.323: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
000434: Jan 12 2017 19:28:56.323: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : openLogicalChannelAck :
forwardMultiplexAckParameters h2250LogicalChannelAckParameters :
network '0A0A0701'H
tsapIdentifier 17174
network '0A0A0701'H
flowControlToZero FALSE
000435: Jan 12 2017 19:28:56.323: H245 MSC OUTGOING ENCODE BUFFER::= 22C000000680134C000A0A07014316000A0A0701431703000100
000436: Jan 12 2017 19:28:56.323:
000437: Jan 12 2017 19:28:56.335: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 23
000438: Jan 12 2017 19:28:56.335: H245 MSC INCOMING ENCODE BUFFER::= 22C000000480101C00000A0A140340B2000A0A140340B3
000439: Jan 12 2017 19:28:56.335:
000440: Jan 12 2017 19:28:56.335: H245 MSC INCOMING PDU ::=
sessionID 1
network '0A0A1403'H
tsapIdentifier 16562
network '0A0A1403'H
000441: Jan 12 2017 19:28:56.335: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
000442: Jan 12 2017 19:28:56.335: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
000443: Jan 12 2017 19:28:58.155: H225.0 INCOMING ENCODE BUFFER::= 2580060008914A000511001100CFBB0A72D82B11E6801BFE2D70D2DADB10800100
000444: Jan 12 2017 19:28:58.155:
000445: Jan 12 2017 19:28:58.155: H225.0 INCOMING PDU ::=
h323-uu-pdu
h323-message-body releaseComplete :
callIdentifier
h245Tunneling FALSE
000446: Jan 12 2017 19:28:58.155: //18/CFBB0A728004/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x682F9BFC, Call Id=18
000447: Jan 12 2017 19:28:58.155: //18/CFBB0A728004/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
000448: Jan 12 2017 19:28:58.155: //17/CFBB0A728004/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
000449: Jan 12 2017 19:28:58.155: //18/CFBB0A728004/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=18
000450: Jan 12 2017 19:28:58.155: //18/CFBB0A728004/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
000451: Jan 12 2017 19:28:58.155: //18/CFBB0A728004/CCAPI/ccCallDisconnect:
Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
000452: Jan 12 2017 19:28:58.155: //18/CFBB0A728004/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
000453: Jan 12 2017 19:28:58.155: //17/CFBB0A728004/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
000454: Jan 12 2017 19:28:58.155: H225.0 OUTGOING PDU ::=
h323-uu-pdu
callIdentifier
h245Tunneling FALSE
000455: Jan 12 2017 19:28:58.155: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A000411001100CFBB0A72D82B11E6801BFE2D70D2DADB10800100
000456: Jan 12 2017 19:28:58.155:
000457: Jan 12 2017 19:28:58.159: //18/CFBB0A728004/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x682F9BFC, Tag=0x0, Call Id=18,
Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
000458: Jan 12 2017 19:28:58.159: //18/CFBB0A728004/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
000459: Jan 12 2017 19:28:58.159: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000460: Jan 12 2017 19:28:58.159: :cc_free_feature_vsa freeing 72C92D78
000461: Jan 12 2017 19:28:58.159: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000462: Jan 12 2017 19:28:58.159: vsacount in free is 3
000463: Jan 12 2017 19:28:58.159: //17/CFBB0A728004/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
000464: Jan 12 2017 19:28:58.159: //17/CFBB0A728004/CCAPI/ccCallDisconnect:
000465: Jan 12 2017 19:28:58.159: //17/CFBB0A728004/CCAPI/cc_api_get_transfer_info:
000466: Jan 12 2017 19:28:58.159: %ISDN-6-DISCONNECT: Interface Serial1/0/0:4 disconnected from unknown , call lasted 0 seconds
000467: Jan 12 2017 19:28:58.167: //16/80A9D2F80100/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x71848324, Call Id=16
000468: Jan 12 2017 19:28:58.167: //16/80A9D2F80100/CCAPI/cc_api_call_disconnected:
000469: Jan 12 2017 19:28:58.167: //15/80A9D2F80100/CCAPI/ccCallReleaseResources:
000470: Jan 12 2017 19:28:58.167: //16/80A9D2F80100/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=16
000471: Jan 12 2017 19:28:58.167: //16/80A9D2F80100/CCAPI/ccCallDisconnect:
000472: Jan 12 2017 19:28:58.167: //16/80A9D2F80100/CCAPI/ccCallDisconnect:
000473: Jan 12 2017 19:28:58.167: //16/80A9D2F80100/CCAPI/cc_api_get_transfer_info:
000474: Jan 12 2017 19:28:58.171: //17/CFBB0A728004/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x68AEF69C, Tag=0x0, Call Id=17,
000475: Jan 12 2017 19:28:58.171: //17/CFBB0A728004/CCAPI/cc_api_call_disconnect_done:
000476: Jan 12 2017 19:28:58.171: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000477: Jan 12 2017 19:28:58.171: :cc_free_feature_vsa freeing 72C92E58
000478: Jan 12 2017 19:28:58.171: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000479: Jan 12 2017 19:28:58.171: vsacount in free is 2
000480: Jan 12 2017 19:28:58.175: //16/80A9D2F80100/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x71848324, Tag=0x0, Call Id=16,
000481: Jan 12 2017 19:28:58.175: //16/80A9D2F80100/CCAPI/cc_api_call_disconnect_done:
000482: Jan 12 2017 19:28:58.175: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000483: Jan 12 2017 19:28:58.175: :cc_free_feature_vsa freeing 72C92F38
000484: Jan 12 2017 19:28:58.175: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000485: Jan 12 2017 19:28:58.175: vsacount in free is 1
000486: Jan 12 2017 19:28:58.175: //15/80A9D2F80100/CCAPI/ccCallDisconnect:
000487: Jan 12 2017 19:28:58.175: //15/80A9D2F80100/CCAPI/ccCallDisconnect:
000488: Jan 12 2017 19:28:58.175: //15/80A9D2F80100/CCAPI/cc_api_get_transfer_info:
000489: Jan 12 2017 19:28:58.175: H225 NONSTD OUTGOING PDU ::=
version 1
iei 8
rawMesg '080282AF1C269E8100036774640000001B52454C...'H
000490: Jan 12 2017 19:28:58.175: H225 NONSTD OUTGOING ENCODE BUFFER::= 6001010001082C080282AF1C269E8100036774640000001B52454C2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A
000491: Jan 12 2017 19:28:58.175:
000492: Jan 12 2017 19:28:58.175: H225.0 OUTGOING PDU ::=
h323-uu-pdu
callIdentifier
h245Tunneling FALSE
nonStandardControl
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '6001010001082C080282AF1C269E810003677464...'H
tunnelledProtocolID
protocolType "gtd"
messageContent
'52454C2C0D0A50524E2C6973646E2A2C2C4E4554...'H
000493: Jan 12 2017 19:28:58.179: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A00041100110080A9D2F8E8CA7187010011010A0A140310A801003A0140B5000012336001010001082C080282AF1C269E8100036774640000001B52454C2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A224204677464011B52454C2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A
000494: Jan 12 2017 19:28:58.179:
000495: Jan 12 2017 19:28:58.179: //15/80A9D2F80100/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x682F9BFC, Tag=0x0, Call Id=15,
000496: Jan 12 2017 19:28:58.179: //15/80A9D2F80100/CCAPI/cc_api_call_disconnect_done:
000497: Jan 12 2017 19:28:58.179: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000498: Jan 12 2017 19:28:58.179: :cc_free_feature_vsa freeing 72C93018
000499: Jan 12 2017 19:28:58.179: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000500: Jan 12 2017 19:28:58.179: vsacount in free is 0
